Wooden deck kit?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Wooden deck kit?
    I hope someone can help?
    Working with wooden deck kits, i assume you have to cut out the various holes for deck fittings such as coal scuttles, vents, AA stations etc. If so would using a wooden deck kit make it much easier to pre paint the fittings, then add the deck, no need for masking or trying not to get paint on the deck when painting the fittings??
  • Defiant911
    • Feb 2020
    • 640
    On the ones I bought all the holes are pre cut so apart from pushing out the odd bit the deck fits straight onto the model.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Thanks Carl, should make painting the fittings a lot easier, i hope!
      • BattleshipBob
        • 6792
        • Bob
        • Cardiff
        Cannot find a wooden deck for KGV, apart from China
        The KGV has loads of stuff on the decks, so either painting or masking is going to be a bit of a nightmare!
          • 18901
          Have you seen this Bob?
          • Defiant911
            • Feb 2020
            • 640
            Mine was from China via eBay and said delivery March but it turned up
            After two weeks.
              • 18901
              Or this....
              I know it’s out of stock, but it gives you a company to search for....
              • BattleshipBob
                • 6792
                • Bob
                • Cardiff
                What make is it Carl
                Thanks Tim, will have a look
                • Defiant911
                  • Feb 2020
                  • 640
                  Mine was Hunter.
                  • Defiant911
                    • Feb 2020
                    • 640
                    Originally posted by Defiant911
                    Mine was Hunter.
