Ships boats colours and rigging of the KGV
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Good afternoon from the winter wonderland that is Cardiff
    I have been doing a lot of reading of the KGV plans, now the usually questions, few more to follow, sorry
    What colours should the ships boats be??
    Tamiya have you paint the fast motor boats with a white hull, with a field blue strip at the top of the hull and the boat itself white, then the cutters all white. had a look at other KGV builds and its all over the place.
    I would have though the cutters would have a white hull and wood interior etc?? If so light or dark wood., need to buy some paint
    and the next
    colour of the prop shafts, Tamiya say gold or bronze, i know the props are bronze?
    Final one
    What size should the rigging be?? John stocks the elastic rigging sets but at different thicknesses etc, my brain is starting to hurt lol
    thanks bob
  • spanner570
    • 15389
    Bob, if there seems to be no definitive answer to the correct painting of the ships cutters etc., just go with the Tamiya call out.
    Just wondering, would the prop shafts be visible? I've had a look at my Tamiya KG5, and all three shafts seem to be encased in 'tubes' Happy to be corrected......
    I used ezeline. Haven't a clue what size, but it was very, very thin. Someone will be along with the answer, I'm sure.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Afternoon Herr Lutjens
      Maybe tubes but Tamiya say paint same colour as the props, where they made of bronze????
      • spanner570
        • 15389
        Don't know. I would think the tubes would be made of steel and the same colour as the lower hull, with glands around the prop. shafts to make the things watertight.
        Maybe someone will let us both know the correct answer?
          I would have thought all the boats would have been grey, apart from the Admirals/Captains barge, which might have been blue & white. Propellers were made of Phosphor-Bronze, or Manganese-Bronze. Initially, they'd be shiny, but soon go a reddish/brownish metallic colour. The propeller shafts would be painted hull colour They ran in glands, where they passed through the hull, and the outer shafts had 'A' bracket bearings to support the length ( no tubes! ).
          The 'A' bracket was the major cause of the loss of the 'Prince of Wales', the KGVs' sistership. A Japanese torpedo hit the bracket, and the propeller & shaft, still rotating at 150rpm, broke free & 'whorled', damaging the inner propeller, but more importantly ripped open the stern gland area, causing severe flooding. Loss of speed & maneuverability made her an easier target for the Japanese Torpedo planes
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            Thanks Dave
            Had a look at a load of built KGV and POW and most are a silver/ metallic colour or what Tamiya say a goldish colour, not one done in hull colour
            Might sign up on the modelship site and ask the question, hang on getting a ship nerd as well as StuG's. Matron, MATRON!!!
              These are more modern ships, but......................
              The USS John F Kennedy in drydock
Name:	new jersey battleship.jpg
              Changing propeller on the USS New Jersey
              Nice & shiny now!
              • boatman
                • Nov 2018
                • 14453
                • christopher
                • NORFOLK UK
                Thanks Dave
                yea look for a ship site
                CHRIS
                • boatman
                  • Nov 2018
                  • 14453
                  • christopher
                  • NORFOLK UK
                  here is a shot Bob of my norfolk's props sharfts if this is any help S/S PROP SHARFT AN TUBE
                  CHRISClick image for larger version
                  • boatman
                    • Nov 2018
                    • 14453
                    • christopher
                    • NORFOLK UK
                    AN i think dave is not far off for ships boats as on my tiger there are blue an white motor launches an sort of grey an brown whale boats
                    chris
                    • BattleshipBob
                      • 6792
                      • Bob
                      • Cardiff
                      [ATTACH=CONFIG]n1142919[/ATTACH]
                      [ATTACH=CONFIG]n1142920[/ATTACH]
                      Nice & shiny now!
                      Need steel toe caps if that fell on your foot:dizzy:
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        chris
                        Cheers Chris
                        Would the inside of the cutters be natural wood or white/ grey etc
                        • boatman
                          • Nov 2018
                          • 14453
                          • christopher
                          • NORFOLK UK
                          Cheers Chris
                          HI Bob try this pic of another hms tiger hope it helps you picture for disscuhion purposes only Click image for larger version
                          • JR
                            • May 2015
                            • 18273
                            Or a StuG. !
                              • 18266
                              First the easy one. Rigging. At 1/350 scale a 1inch wire would be.....well tiny. If you find two sizes where you can see the difference, use the thicker for stays and the like, (cables that are holding things up) and the thinnest for radio wires. even if you did the whole ting in the same size, no one will ever know.
                              The ships boats...read ten books and you will get ten different answers. Well I did.
                              Many though agree that under active service most boats outside where ships colour. The very bottom of the hulls white. ( to aid finding them if they capsize at sea). The insides where nearly always wood colour. The captains launch could have have deep blue sides white bottom. If an Admirals ship it might have been dark green.
                              At sea all boats would have been covered with tarps and all boarding ladders and gangs stowed..
