What’s the difference between a ship and a boat?
    I'm with Dave. Anything that can't go further than inshore water is a boat.
    Could you use requiring a crew as a definition for a ship? Opposed a boat that requires only one pilot.
    • Bortig the Viking
      • Mar 2019
      • 780
      #17
      Is it now a plane? Getting confused now, where's my Meds!!!
        Well.....driver doesn't seem right. That implies wheels. Operator? Captain doesn't seem right without a crew. Helmsman?
        • bilbo
          • May 2018
          • 123
          #19
          Originally posted by Ian M
          Ok plan b
          Big floaty thing = ship
          Little floaty thing = boat
          Sinky floaty thing = submarine ( if it can float again, otherwise it's just a wreck).
          does that mean a rowing boat is a ship until its next to something bigger? :tongue-out3:
            • 18903
            I think the only definition w3 can agree on is that a Boat starts with the letter B, and a ship starts with the letter S.....
            By the way, does all this mean that Boaty McBoatface should have been called Shippy McShipface?
            • stillp
              • 8093
              • Pete
              • Rugby
              #21
              That's another thing - ferry boats. I don't think I've heard them called ships, even the big cross-channel ones.
              • Peter Gillson
                • 2594
                #22
                All a matter of size - I recall a harbour pilot explining it to me by saying that you can ship a boat in a ship but you cannot boat a ship in a boat. Perhaps he had been at sea too long!
                Peter
                • adt70hk
                  • Sep 2019
                  • 10409
                  #23
                  Actually no! The research ship (note ship) was given the name the Sir David Attenborough. Boaty is the name of the submersible it carries - a boat on two counts.
                  I will now apologise for trying to introduce a modicum of sanity into what had become a very funny thread!
                  Bilbo - thanks for asking the question. Who knew it could get so complicated, not to mention funny!
                  ATB.
                  • boatman
                    • Nov 2018
                    • 14475
                    • christopher
                    • NORFOLK UK
                    #24
                    WELL in my opinion the shell welder is big enough to be called a ship ok:tongue-out2:
                    chris
                      • 18269
                      Originally posted by bilbo
                      Looking to make sure I post in the right section. I’d assume that the Shell Welder is a ship but not sure...
                      In conclusion:
                      Post away and If I think its in the wrong place I'll move it. :tongue-out3:
                      Some interesting theories in this thread as to what is what. Regarding the forum sections as it is and will continue to be Big floaty things are a ship. ie warships, cargoships and the like.
                      Small floaty things such as MTB's, launches, patrol boat, rowboat, are boats. Things that are designed to go under the water are a submarine.
                      Diorama of boats/ships live in the diorama section.
                        That definition would make this a ship:
                        [ATTACH]413498[/ATTACH]
                        And this a boat:
                        [ATTACH]413500[/ATTACH]
                          Good point, however I would class those as purpose built exceptions and examples of when the definitions are intentionally skewed in pursuit of either an extreme acievement or a localised logistical problem.
                          • stillp
                            • 8093
                            • Pete
                            • Rugby
                            #28
                            Good point, however I would class those as purpose built exceptions and examples of when the definitions are intentionally skewed in pursuit of either an extreme acievement or a localised logistical problem wrong.
                            Fixed it for you!
                              Agreed about the rowboat, but the container ship is just a specialised example of a very common type of vessel on European waterways that you can see anywhere between the mouths of the Rhine and the Danube and beyond.
                              My point, really, is what I said before: I don’t think there’s a meaningful difference other than the distinction any given source tries to make between “boat” and “ship”. As far as I can tell, they’re just two words that evolved in parallel and for some reason, now have to have distinct meanings in some circles.
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #30
                                Does Tonnage enter into this anywhere.........or have I missed something? The Carrier I was on had seven decks above the flight deck and seven decks below the flight deck.....some of those below the waterline.
                                Try that in a boat.
