Hi all
So after deciding to finish my boat I started ages ago, I had the hull all nicely painted, and it just looked to nice and new, so then I saw a picture of a older mid 1900’s riveted steel hulled boat and thought how much better it looked. So me being mad got the hot air gun out and stripped my nice new paint off and started again. (I also made the keel deeper to add buoyancy to allow for a bigger heavier battery to be used for a longer running time.)
A good way to get a older painted over rusted hull effect, is apply a single layer of fibreglass tissue, then with cured using a flat spatula, thinly smear filler over to fill in most of the imperfections, and then just sand lightly. The end result is a slightly pitted and marked hull, that of old rusted but cleaned and painted over metal.
Then onto the rivets. The boat I saw in the picture had single line rivets with a joiner strip halfway down. So I set about adding the rivets. I’m up to about 1000 at the mo, with only one side done and about another two thousand to do. (so thats mark out the line, 1 every 5mm, drill the hole, push the cut down nail in, then hammer till just proud of the surface. ) I couldn’t find any proper miniature rivets so found some panel pins in a local hardware shop with small neat heads on them. Downside is they need cutting down as they are to long, which has given me loads of blisters from the cutters, and cutting so many.
This picture was taken last night, where now that side is nearly done. Also once a coat of paint is added, it looks much better.
Don
[ATTACH]7872.IPB[/ATTACH]
[IMG]/monthly_2007_09/57272b73197b3_hull1.JPG.ae8913b6633502068c9c43ab89 9bf4fa.JPG[/IMG]
[ATTACH]15684.IPB[/ATTACH]
