Sorry, another ship question!
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Evening and sorry for another question!
    After adding the boot topping and painting the decks i plan to varnish the hull, would varnish on the decks cause problems gluing the funnels etc in place??
    Thanks yet again Bob
    • 22770
    Just mask the area where the funnels and other things go, then varnish just to make sure Bob,
    • boatman
      • Nov 2018
      • 14453
      • christopher
      • NORFOLK UK
      HI Bob m8 yes Ian is right do as he has said an you should be ok
      chris
        • 18901
        Treat varnish the same as paint Bob. Scrape it off at the joins and you’ll be fine…..actually I find Revell Contacta melts through paint pretty well, so rarely scrape joints when carrying out final assembly.
          • 15679
          Like Tim I find that a quick scrape/light sand on the join line allows the styrene cement to work fine even if there is some paint or varnish left. If in doubt you can wick in some thin CA along the join.
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            Many thanks all, yet again:thumb2:
            Much appreciated
            Bob
            • boatman
              • Nov 2018
              • 14453
              • christopher
              • NORFOLK UK
              now Bob m8 lets see some action lol an you must have confidence in yourself as i hnow you can do it boyo
              chris
