bending brass is there a right way?
    hi all
    is there a proper way to bend brass tube? as i need to make 2 x circular rings but dont want them all over the place!! the brass is 1.5mm thick solid type
    many thx
    M.I.B:thinking:
    I'd just bend the brass around a piece of round bar, roughly the same size as the internal diameter of the ring you want to make. then continue to bend the brass around the bar to make a kind of spring, then saw across to make the separate rings.
      Hi MOB,
      It all depends on the diameter of circle required.
      Normally I just do it as Alan suggests but anneal it first, that way it will be almost the same size as what you are wrapping it around, otherwise it tends to spring open too much.
      For larger than average I use a set of slip rolls with the round grooves on the rollers designed for doing this sort of job.
        slip rolls??
        hi bog(sorry)
        what are slip rolls with the round grooves ?
        cheers
        M.I.B:thinking:
          MIB,
          This will show you a piccy of a slip roll. If you look carefully at the rolls you will see some grooves at the end, these are for fabricating rings.
            cheers john
            not worth buying one to do 2 rings!!
            many thx
            mick
              There is also the hand held copper pipe bender. I use one of them for pipe work on the steam plant. I'm sure with some annealing it will be OK with brass tube as well.
                What diameter are you trying to get to?
                  brass
                  hi lads thx again for rplys its a wintergarden for a boat tower
                  the top ring is 3 & half inches measured from the widest part in the centre
                  and the second is at a rough guess is 3 inches pic included
                  thx again
                  M.I.B
                  [ATTACH]15816.IPB[/ATTACH]
                    That is a wrap around paint tin job, but as I said before anneal the brass first. Just heat it to a medium red colour and either drop it into water or let it cool down naturally, if it hardens up before you have finished bending, just repeat the heat process. Not a job for machinery.
                      Brass Wintergarten rings
                      Hello MIB, do you mean like this ?, i heated them up a bit to get them more supple then found a paint tin of the correct size and bent away a little at a time and hey presto done. Hope its of some use sub.
                      [ATTACH]7879.IPB[/ATTACH]
                      [IMG]/monthly_2007_11/57272b734b510_DSCF0027(Small).JPG.234722951ac9b9ad 25d1a78c821e2d12.JPG[/IMG]
                      [ATTACH]15817.IPB[/ATTACH]
                        Help Please!!
                        hi all
                        going crazy here! does anyone no who will make the wintergaten rails for a 1/35 scale tower asjustcant get to grips with as well as loads of brass in the bin
                        please help
                        mib:smile11: any offers subeace:
                          Wintergarten rails
                          Hello MIB.
                          I use 2mm dia brass rod or 1/16 in old money. Put it against the tin and bend it from the centre outwards not from one end, and do it equally at both sides at the same time. You should be able to do it with the rod cold as its only thin.
                          Bend it past the centre line and it will spring back a bit then bend the sides for the tower sides when the dia is right. If it is a little out you can adjust it when you put the uprights on and solder them to the ring. Go slowly and use the full 12 onch rod don't use tube.
                          Hope this is of use if not I dont think you can buy it pre-done anywhere
                          :regards:
                            hi
                            sub tried that m8 and all that happens is the thing justs springs back out!!
                              You were told before, it has GOT TO BE SOFTENED BY HEATING, OTHERWISE IT SPRINGS BACK.
                              If you live anywhere near Crewe, bring it round and I will do it for you. While you wait
