Rigging practice
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Rigging practice
    Having a tidy up found this!
    No idea when I bought it, its 1 350 to 1 200, so should not be too thick? So cut some lengths of sprue and
ID:	1169790Click image for larger version
    Not to bad me thinks, do you though????
    Found best way was to slightly over estimate the length then trim after, the joining piece is a bit too short though. Love how elastic it is!
    Biggest problem was how fast the accelerator evaporated, dipped one end in, then tried another length and it had gone, tried the spray adaptor but to much for me
    [ATTACH=CONFIG]n1169789[/ATTACH]
    [ATTACH=CONFIG]n1169790[/ATTACH][ATTACH=CONFIG]n1169791[/ATTACH]
    Bob,
    that's the way to go! - The accelerator - that is where a 3rd hand would be very useful. I have decanted a bit of kicker into a little tube, then used a paintbrush held between my teeth to apply the kicker, with one hand holding the thread & the other applying the CA. It does work, but you can end up with brush hairs stuck to the joint. I had toyed with the idea of fine capillary tubing, controlled by breath, but the kicker is nasty stuff!
    • rtfoe
      • 9072
      Some say to add the kicker to the point you want the end to stick then place the end and a touch of the CA and it will harden instantly.
        • 18266
        Very tidy Bob. You might want to make some thin sprue and try with those as well. One line does not pull to much, but when you start to add more they all have a tug at it.
        I have a signal yard with 16 or so lines on and after it was done it was like a banana!
        My method of using kicker as CA. Only needs two hands, not brush or teeth! lol.
        A dot of CA on the target part. (DONT use the thin runny stuff, use a medium thick one). Offer the part to attach to the blob and give it a spritz og kicker. Job done. Thinking as I wrote that you kan even do it with one hand but probably not advisable.
        Question. >That thread you used, is it smooth and doesn't catch on rough fingers or did you tweezer everything?
        • Mark1
          • Apr 2021
          • 4156
          Your just showing off now bob :smiling3:
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            Bob,
            Cheers Dave, read the accelerators ingredients and yes not nice!! No naked flames lol
            Thanks Richard, works well when it's actually liquid lol
            Hi Ian, to answer your ?? Smooth. Tried by hand and tweezers.
            No way Mark, very early days lol
            • JR
              • May 2015
              • 18273
              Looks good Bob, plenty of practice before the main .
              • stillp
                • 8087
                • Pete
                • Rugby
                Good idea to make up a practice rig Bob.
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  Very true, when you see some of the rigging on many models, my god will my nerves hold up lol
                  Thanks Pete, next is to make 2 bog standard masts for multiple threads, headache tablets in stock!!
                  • Allen Dewire
                    • 4741
                    • Allen
                    • Bamberg
                    Damn Bob,
                    Here I was thinking this post was about where you could buy more rigging after using all of yours up doing tests............It is looking good though and I wish you all the luck doing your floaty thingy rigging..............
                    Allen
                    • BattleshipBob
                      • 6792
                      • Bob
                      • Cardiff
                      Damn Bob,
                      Allen
                      Cheers Allen, slow but steady!
                        • 15655
                        Nicely done Bob. I'm impressed.
                          • 18890
                          Looks very good to me Bob. It should do the job quite nicely :thumb2:
                          • scottie3158
                            • 14199
                            • Holbeach
                            Nice work Bob I just used the EZ line for the first time. I put a drop of CA at the contact point then dipped the line in the accelerator and touched it in place and it seemed to work well. It was a good idea to build a practice rig.
                            • BattleshipBob
                              • 6792
                              • Bob
                              • Cardiff
                              I'm shocked lol
                              Cheers Tim, like the infini stuff and there's a lot of it!
