my first warship build
    hi i'm new to this forum and to model boats
    for a while now iv bin planning on buildin one
    so the other day i tho its time too
    the hull is coming on a treat ok took me 2days and its stil not finished and i tho id neva use soo mutchglass fiber hehe
    if you would like to see some pics of were i'm upto now visit my website www.myPCbuild.piczo.com capital PC.
    its at the top of the list MY WARSHIP BUILD. iv put it on my website for now till i set a site up just for this build.
    im not working from eney plans as i think thats my first mistake just a few looks at some real warships got me to were i am now
    i wos wondering if eneyone could give me advice on wot size/power motor to use i wos thinking using led acid batterys two 10v. and two 12motors with a 20v speed controler..if this would be ok?
    eney ideas or advice would be srate thanks eace:
    Hi, welcome.
    Two lead acid batteries should be fine, but do you mean 12 volt?
    Leave the speed controller until you decide on motor(s).
    The best thing would be to build the hull to the point where the prop shafts are to be fitted, this will give you some idea of how much actual space you have for the motor(s), more importantly, it should allow you to measure the likely height of the shaft in-board, as this will partly determine what size motor you can fit. If you want to drive the shaft direct you will need the motor diameter to be small enough so that the motor and prop shafts line up. This could mean too small a motor for the hull size.
    The alternative would be to raise the motor(s) and use indirect drive. This could be a gearbox or belt dive, depending upon the space available, it sounds daft, but the available space will be a lot smaller than you would guess from a 7 foot hull, it's all down to the prop-shaft angle.
    J.
      Hi and welcome Pete, she looks pretty narrow in the beam (as the sailor said to the ...oh never mind) What about ballast ? Gonna need a ton. Pity you didnt think of making a manned model ( in two 7ft halves) See www.kittiwakeboats.co.uk under warships.
