Hi all
I need to remove prop shaft from a wooden hull. The old bushes are worn and the shaft corroded. New shafts are 6mm OD tubing, mine is 8 mm and I cannot therefore just replace bushes. Any tips for getting the old shaft out with minimum damage.
Carpcruncher
Carpcruncher
