Hi,
I am now doing a project on underwater robot control system, and I bought an ADC-1 from subtech and intent to use it to control my depth. But during the testing stage, i realized that it is only sensable until 15cm, I thought it can measure until 2meter?
My setup is as follow, I connect the rubber tube to the bottom of a high cylinder water container, i wrote a simple program to capture the output from ADC-1, and also i can change the value input to ADC-1.
During the testing, I kept adding water into the water container and observe the variation of output (which is 915 -1830) from ADC-1, at the same time, i can change the input also. But no matter wat input i gave to ADC-1, it seems the maximum value 1830 would not change after 15cm depth of water was filled into the cylinder.
Can you give me some suggestion on this? Thanks in advance.
sieseason
sieseason
