Cutting gun ports in the hull of HMS VIctory 1:74 scale
    Further to my earlier query re colour schemes for the Victory I'm now looking for tips on cutting multiple gun port holes.
    Is there a way to make this easier than carving from corner to corner? E.g. using a jig saw with a fine blade without 'ripping' the wood veneer in the process.
    Originally posted by \
    Further to my earlier query re colour schemes for the Victory I'm now looking for tips on cutting multiple gun port holes. Is there a way to make this easier than carving from corner to corner? E.g. using a jig saw with a fine blade without 'ripping' the wood veneer in the process.
    Hi Paul
    Sounds like my advice is too late but I built my gunports in using the planking, if you look at HMS Unicorn on peter22 you will see what I mean
    if it's not too late I could post details on forum
    best of luck
    Peter
      Unfortunately this isn't a Corel kit where they design their hull planking plans to account for the gun ports. In fact I have added a second layer of veneer planking to form a better hull look and feel.
      Cutting of the gun ports is explained by using the plan drawing as a guide tracing the plan, laying it over the model to mark the positions, drill 2mm holes in each corner and then connect the 'dots'.
      Constructo is almost out of business I think.
        If the hull is made of soft wood, try a small square pastry cutter (if you can find one) and press firmly and the carefully eke out with a very sharp stanley/craft knife..drilling tends to leave circular edges in the corners...
          If memory serves there is a "frame" around the gunports. Why not fix this to the hull first, then cut out the planking inside and behind it?
          Rick
            Unfortunately the frames are built after the holes are cut. I have some small chisel style blades for my Exacto knife which may work. Still a lot of tedious work though, but then so is tying 2000 odd clove hitches for the ratlines.
