You will recall a while ago I chatted about my very old boat. I have managed to get a couple of evenings work on it and it is basically set out. I am ready to bolt the rudder servo to the bulkhead, and fit the radio gear, speed controller and wiring etc.
Are there any golden rules as to siting of radio, wiring, speed controller etc and any tips? I was going to run radio wires on one side and battery/motor on the other.
The radio will be put in a small box to splash proof it, will a metal box cause any problem or , I assume not seeing as the aerial wire is what brings in the signal.
Picture attached. The battery can be moved along the supports using the frame to tinker with trim. Soon to be painted grey inside.
[ATTACH]17808.IPB[/ATTACH]
