Engels U177
    Will she be launched in time for the Start of Season show at Richmond (May 22) or Edinburgh (May 8)?
      Richmond? Edinburgh?
      I need a passport to get north of the Thames!!!!!!!
        Richmond? Edinburgh? I need a passport to get north of the Thames!!!!!!!
        Ken is the only guy that I know who has a range on his car depending on the length of main cable he can ge hold of :shhhh: :wheelchai :wheelchai :wheelchai
          :smile1:
            More U-177
            Top hull fastened to bottom hull.
            Pretty well complete.
            Now I need to find a suitable pool to test the ballast, functions, etc.
            [ATTACH]7600.IPB[/ATTACH]
            [ATTACH]7599.IPB[/ATTACH]
            [ATTACH]7598.IPB[/ATTACH]
            [ATTACH]7597.IPB[/ATTACH]
            [ATTACH]7596.IPB[/ATTACH]
            [IMG]/monthly_2005_04/57272b6e5dba8_Sub6April2005-a.jpg.0db28398eabab024debbcd5ba31f5ea4.jpg[/IMG]
            [IMG]/monthly_2005_04/57272b6e5c37b_Sub5April2005-a.jpg.6e56685225adc4c64a4489d95ae864f8.jpg[/IMG]
            [IMG]/monthly_2005_04/57272b6e5aaca_Sub4April2005-a.jpg.7fd078ab613aca42cf56ef1ce3b31854.jpg[/IMG]
            [IMG]/monthly_2005_04/57272b6e59247_Sub3April2005-a.jpg.77d7919fe6f18b7d603c034cb438bdb1.jpg[/IMG]
            [IMG]/monthly_2005_04/57272b6e5772c_Sub1April2005-a.jpg.17eb5588094180f21fc03ded90cafd58.jpg[/IMG]
            [ATTACH]12891.IPB[/ATTACH]
            [ATTACH]12892.IPB[/ATTACH]
            [ATTACH]12893.IPB[/ATTACH]
            [ATTACH]12894.IPB[/ATTACH]
            [ATTACH]12895.IPB[/ATTACH]
              One more photo
              View of stern and rudder/planes assembly
                Forgot the photo!!!
                [ATTACH]7601.IPB[/ATTACH]
                [IMG]/monthly_2005_04/57272b6e5f4e7_SternApril2005-a.jpg.3582e46ff76d1b9741d5854fa600fbab.jpg[/IMG]
                [ATTACH]12896.IPB[/ATTACH]
                  coming on a treat there ken, you got far to go ?
                    Just checking the watertight compartment for leaks, then the diving tests.
                    I've got to wait until a friend has got his large paddling pool set up ( better weather needed) as the boat is approx 6 feet long and won't go in the bath!!!!!!
                      U177
                      Hi Ken
                      I have only just bought the Engel U177 and with regards to the plans is it correct that you receive the large 1.1 scale plan and a booklet entitled Buildng instruction & Assembly drawings?
                      It just appears so daunting without a step by step guide unlike which came with my Robbe Kit.
                      And in reality is it a straight forward build! Many Thanks
                      Regards
                        Hi Steve,
                        Yes, the Engels kits come with a 1:1 plan plus instruction booklet(s).
                        Putting it together is fairly straight forward, however:
                        The kit comes with the upper & lower hulls taped together, once they are apart, getting them backtogether is a bit of a fiddle.
                        The diving chambers are a real tight fit in the hull.
                        With the big lump of ballast in the hull, it becomes really heavy and that has to be in before the diving chambers and electrics are installed.
                        You can always e-mail me on kenparker@verwood-dorset.fsnet.co.uk
                        KenP
                          Being a novice to the world of RC Subs (beat up second hand U-47) and looking at what best to buy as a kit can anyone give me an idea of just how tedious the process of cutting the free flooding slots are in such kits as the Engels one. I really prefer the Engels U-177 standard of kit to the Robbe but the slot cutting is putting me off.
                          Thanks
                            Cutting all the free flooding slots is pretty tedious. Most are on the upper hull but their are quite a few, forward and aft, on the lower hull.
                            The hull on the Engels is fibreglass. For each slot, I drilled a row of holes, joined them together with a round needle file, then filled to shape.
                            It is time consuming, I found the drilling worse than the filing !!!!
                            if you want a static diving sub then you can't get round doing this chore.
                            If you are OK with dynamic diving then look at the new Robbe kit. The slots are preformed
                              Ken,
                              Thanks for the help. I take it the hull has the slots scribed into it for you to follow but my worry is keeping them all perfectly aligned. I am toying with the idea of setting up some sort of small milling head set up on a rail. Food for thought for the project but I am still looking at acouple of years ahead.
                              Thanks again
                                Filing the holes on the Typhoon was a bind too! 207 of the things and they had to be square. I started by drilling 4 small ones at each corner with a larger one in the middle and then filing outwards to each corner. The hole corners were then finished off with a triangular file and the hole squared up. You need to have patience!
