There's nothing I am aware of in that scale, but a little bit of work on the photocopier should be all you need, or check your local print company. For plans of weapons try going to :
The main problem at building to the scale that you are doing is that the majority of your fittings will have to be scratch built, any drawings that you get hold of will have to be re-scaled to suit, so you have alot of work there my friend.
Hi Ross I know this post is a bit late but it probably dosn't matter whatever weapon/s you put on a PT Boat as somewhere in the world they where fitted, from rockets to anti tank guns and all in between so it might be worth also looking in vehicle mounted equipment
