Is there any courses or books available on the construction of brass fittings in the UK or Europe? I know about photo etching but would like to learn more about fabrication and casting.
I don't really need any info on etching per se. I am more interested in learning true fabrication and machining of brass fittings; such as the products WEB used to produce.
Hi, I can talk you through fabrication of anything brass. I have made brass masters for 35 years for the casting industry and endless brass fittings for one-off boats for clients. It's really just a case of breaking everything down into what can be turned on a lathe and what can be cut, folded and filed, then silver soldered together. PM me if you like for my e-mail address.
