American Pusher Tug / Towboat
    Hello all, I am in the midst of building from scratch, based on the Free Plan in Model Boats magazine of February 2004, an American Towboat. It is coming along quite nicely now and will be in the water very soon.
    cheers
    [ATTACH]7578.IPB[/ATTACH]
    [ATTACH]7577.IPB[/ATTACH]
    [ATTACH]7576.IPB[/ATTACH]
    [IMG]/monthly_2005_04/57272b6e3f967_RedHamishIV110405paintedsternview.JP G.79d8c7f33e703dfa0cbabdc4fafd58ec.JPG[/IMG]
    [IMG]/monthly_2005_04/57272b6e3e566_RedHamishIVpainted110405.JPG.f57ae7f 8e7e45b278d6fd461ba1f859e.JPG[/IMG]
    [IMG]/monthly_2005_04/57272b6e3c907_RedHamishIVpaintedbow110405.JPG.ab70 a453f8d150d5eb9ad02bee879c16.JPG[/IMG]
    [ATTACH]12871.IPB[/ATTACH]
    [ATTACH]12872.IPB[/ATTACH]
    [ATTACH]12873.IPB[/ATTACH]
    Looking good,
    Will be even better with all the fittings on etc....I have those plans too as I thought this looked like a nice easy fun (and useful) model.
    I say useful because there have been many times down my local club pond where boats have died out in mid-water with no breeze to blow them back in, It's usually another member that comes to the rescue to push it back to the side with their boat. That is fun in itself just trying to get lined up right !!!
    Keep us posted with the pics
    Regards.......Mark.
      Looks good but with the high superstructure I would advise care in any wind. If you have a problem with wind then could I suggest that you add a keel made from clear plastic, a very popular chocolate wrapped in gold paper has a box with a nice sized lid which can be used for that purpose and with it being clear is not seen when the boat is in the water and can be removed for display purposes if held in place with screws in a slot in the side of the lid.
        "If you have a problem with wind then could I suggest that you add a keel made from clear plastic" :hehe:
        Sorry couldn't resist that one, if you have that problem though you may want to add some foghorns too :music_too
        :hehe::hehe::hehe:
        Regards.........Mark
          "If you have a problem with wind then could I suggest that you add a keel made from clear plastic" :hehe:Sorry couldn't resist that one, if you have that problem though you may want to add some foghorns too :music_too
          :hehe::hehe::hehe:
          There is a much better solution for a wind problem, Don't eat so many heinz beans. You could end up with a DIY Jacouzi. :jeer: :diespam: :diespam:
            hi Jim,
            I'm also interrested in building one of these tug/towboat. Can you let me know where could I find the plans you're using ?
            Thanks in advance,
            Jiboullet
              Plans
              Hello all, in response to Jiboullets' question. The plans were inside the February 2004 Model Boats magazine which you should still be able to get from them as a back copy I should think. Failing that I'd be happy to provide you with more details as it is a very simple form of hull which as has been stated elsewhere does not like the wind! I built in addition a barge of slightly larger proporetions using the same method and have found this to be entirely satisfactory in efen some pretty rough wind and weather. The big draw back is the turning circle is of about 3M radius wwhen even the slightest wind blows. Perfectly acceptable 1.5M radius when there is no wind but just how often does that happen here in Scotland?
              cheers
              p.s. if you want more details just send me an e-mail or IM / PM through the forum.
                Jim,
                I was tempted by a card one of these about a year or so ago on Ebay but missed out at the end. It was obviously made from the Model Boats plans but had no propulsion. MY intention was to have fitted two independant shafts and drive it pretty much as per a tank, which I would have expected to have made it very manoeuverable.
                Whay propulsion configuration did you go for?
                  Propulsion
                  Hello all, sorry for the tardy reply Richard been rather busy and simply not checked any opf the forums this week:emo10: Yes I went with the independent shafts with separate Esc's off of a single 12v 7Ah SLA battery fused with a blade type 10A (couldn't be bothered to test what it actually needs the esc's are 20A rated Actionkit) using 35mm 3 blade brass props. If I were to do ita gain I'd be seriously considering putting in rudders too.
                  Mine works incredibly well but has a tendency not ot respond to the turn if there is the slightest bit of chop. pushes a single barge which is about 1 1/2 tiimes it own size, weighing in at 12kg laden, with ease. Looks good on the water too.
                  I hope this inspires the confidences for anyone to give it a go I like it a lot
                  regards
                    Interesting, I thought it would do well with independant shafts but I hadn't realised how susceptable it would be to wind. Pretty obvious really with such a flat bottom.
                    Got to be worth while having one at the pond side for any meetings!!
                      A good shot of it
                      Hello all again, Richard I thought that you may like to see the photo taken of Red Hamish IV and its' barge fully laden and under way at the Ayr MBC open day back in April this year. This was taken by Drew Young a fellow modeller from Dumfries-shire who kindly sent a CD full of his photos taken that day (silly %&g$%£ I'd forgotten my camera and it was 188 miles away at home! )
                      Thanks Drew. As you can see it can go at a reasonable pace in the right conditions using the two 540 motors on direct drive.
                      cheers
                      [ATTACH]14227.IPB[/ATTACH]
                        Jim, That really looks the part and goes well with the barge. I guess she will be a bit less wind prone when she is attached to the barge like that.
                        Nice to see a Model Boats plan finished and in service and I think this one has proved to be more popular than any other. I can think of about four examples of this model I have seen but I can't remember seeing any other plan actually made up.
                        Thanks for the picture and the thought.
