Hood vs Bismark?
  • Alan 45
    • Nov 2012
    • 9833
    Hood vs Bismark?
    my next build is going to be a sea battle of hood vs bismark , on my other sea scene I used paper mache for the see but this time im thinking of doing it with polyfilla and was wondering if anyone new the best was to seal it due to it being porous.
    any advice would be great.
    • 18266
    Have a look at some of the sea bases made by a couple of the members on here using clear silicon bathroom sealer....Looks really rather good and after all accounts simple to do...
    What scale is this going to be...
    • spanner570
      • 15391
      Alan, P.V.A. should do the trick, but it will need a few coats. Also beware of putting polyfilla on too thick...it will crack. Best applied in 2/3 layers.
      I'm sure other members have their own way of sealing the stuff and will be along soon!
      Ron
        I'm with Ron on using pva and building up in a few layers.
        a little trick I use is to add a very dilute pva to the filler mix. this will help to stop cracking if you get it a bit too thick.
        • Alan 45
          • Nov 2012
          • 9833
          Originally posted by \
          Have a look at some of the sea bases made by a couple of the members on here using clear silicon bathroom sealer....Looks really rather good and after all accounts simple to do...What scale is this going to be...
          thanks guys for the advice. scale is going to Tamiya 1/700 waterline series
            • 22770
            Hi Alan on my King George V build i used clear sealant for the water effect i got some polystyrene and cut the shape of the ship out of it then painted it the sea colour then put the clear sealant over useing a metal spoon ( wet the bottom of it to stop the sealant sticking to it ) then tapped the sealant with the spoon to make the tops/crest of the waves then when dry just painted the tops/crest white [ATTACH]54636.vB[/ATTACH] [ATTACH]54637.vB[/ATTACH] [ATTACH]54638.vB[/ATTACH] [ATTACH]54639.vB[/ATTACH] [ATTACH]54640.vB[/ATTACH] [ATTACH]54641.vB[/ATTACH] Hope this helps
            [ATTACH]56839.IPB[/ATTACH]
            [ATTACH]56840.IPB[/ATTACH]
            [ATTACH]56841.IPB[/ATTACH]
            [ATTACH]56842.IPB[/ATTACH]
            [ATTACH]56843.IPB[/ATTACH]
            [ATTACH]56844.IPB[/ATTACH]
            • Alan 45
              • Nov 2012
              • 9833
              they look fantastic I have a piece of polystyrene that would be good to have a few goes on to get it right.
              cheers for the photo's
                hi there i have just finished two boat dios with water effect one entitled last moments and attack run i hope this will help.
                Scott
