Massive help required - hull damaged.
    Help!
    I'm building the Alanger 1:350 Typhoon submarine, and there's been an accident.
    the kit fell from its stand and came to rest on the heater whilst I was on the phone, melting a large section of the upper hull. I have cut the section away, to salvage the rest of the hull. My question is: how to fill the gap? Oh, and it needs to be hollow...
  • peterairfix
    • Jul 2012
    • 11077
    First of all may i say ouch.You might be able to use plasticard.
    Thats my suggestion but there may be others that may know .
    Peter t
      • 18271
      Yep. Plastic card is the way to go with that one.
        Thanks guys.
          what about a piece of poly pipe the same diameter as the damaged area then plastic welded into place then tidy the join up as required
            As said, but make 3 or 4 circular diaphragms to help keep the shape. Derek
