Steamer Ben Ain
    Well I have to admit to feeling quite honoured that I have inspired you to buy the same ship.
    I do confess though that I have sometimes wondered about the choice of steam plant for the propulsion. I am sure it will be worth it in the end but it has taken vast amounts of time, money and effort to get it together. The model has also required a considerable additional amount of work to accommodate it which has slowed the project down considerably.
    You have certainly already obtained the best source of additional information in the form of the CV Waine book but I have also purchased a number of other books by the same author. They do not necessarily give ship specific information but do supply a wealth of additional pictures and drawings that I have used on the model. One such item was the correct layout of the rivets on the hull plating and another was the arrangement of the bulwark stays, which I didn't think were particularly realistic as per the kit.
    Another invaluable source of information are from period pictures. One of the most usefull I found on a site called Rhiw.com. You will even find a picture there of the Ben Ain as the Doris Thomas which provided a couple of interesting points that I will be using. I also found a usefull period shot of the inside of a hatch that I will be using to complete the hatch of the model.
    Anyway good luck with your kit, if you want a CD with the Mountfleet model pictures on it send me a PM with your address on it and I'll get one off to you.
      Richard it does lok the dogs danglies if i could suggest when weathering less is more!!! but a lot of people forget about the build up of green slime and algae that seems to cling to slow moving boats :-))
        To be honest Nigel, from what I have seen of period pictures, if I made it absolutely realistically the model would look a bit of a mess!
        I have been convinced for a long time that the main key to the success of weathering is knowing when to stop!
          Hi would love the pics on the cd only problem is I am also new to forums so do not know about p/m's, took me quite a while to work out how to post a message ! Mark
            Mark,
            Never be afraid to ask, I'm still relatively new to it all as well.
              I think i've sent you a PM but I'm not sure if you will get it? Mark!
                PM recieved, well done! CD on its way today.
                  Many thanks Richard, let you know when I get it.
                  Regards Mark.
                    less is more 100% of the time
                      Hi Richard, many thanks for the pics cd got it on saturday but been away over the weekend so only just seen them, They will be a great help, now I will have to get started on the thing, speak to you again soon.
                      Regards Mark.
                        Glad to be of help Mark. I look forward to your updates.
                        All the best
                          Wow, a truly awesome model Bunk.
                            Thanks Tiger
                              i have a 1 to 24th scale puffer half built, i too will give the riveting a go, i have been putting it off !- but your pictures inspire !- the mad thing is i have used the cyano gel for this purpose before ( for rivets on a lifeboat )and also to replicate thick solid seam welds on the pressure vessel of my research submersible- but all those little dots AAAHHHH !
                              need to buy in some activator for the job !
                                Guy,
                                It probably took most of my spare time for a week, mainly as I discovered that the rivets were in double runs, but the result is a world apart from what I started with. Well worth the effort.
