They say a change is as good as I rest; I'll let you know when I am finished this next project. This has been a long term ambition of mine, so I am going to take it nice and slow. For a review of the kit and some personal history, please see the link below.
http://www.scale-models.co.uk/product-reviews/12060-side-steam-trawler-milford-star-1-48-caldercraft.html
Here are a few shots from the Box Art from the Milford Star Kit.
[ATTACH]30708.vB[/ATTACH][ATTACH]30709.vB[/ATTACH][ATTACH]30710.vB[/ATTACH]
[ATTACH]30711.vB[/ATTACH]
From the history provided in the link above, I plan to convert the Oil Fired Milford Star to its original coal fired Aberdeen Trawler of the 1930's
First job is to smooth out the inside of the GRP Hull in way of the Bulwarks; photo below shows the roughness.
[ATTACH]30712.vB[/ATTACH]
Once this is done I will fit the Rudder, but as this will be a static model, I will not be fitting the propeller shaft tube, and will leave off the propeller till near the end.
The main deck will then be fitted, I have bought some white ash strips, and would prefer to plank off the main deck, rather than use the overlay sheet provided, see photo below (rough cut) but I have to try some weathering of both to see which gives the best results.
[ATTACH]30713.vB[/ATTACH]
As you can see below, the hull plating has been moulded into th GRP, if a little exaggerated. There are no rivet details, so I plan to use wet slide decal rivets which I have sourced from the USA. This will be used on the Hull and all superstructure.
[ATTACH]30714.vB[/ATTACH]
I haven't given up my aircraft modelling entirely, as I will fit in the odd kit during this build.
Cheers Derek
[ATTACH]35824.IPB[/ATTACH]
[ATTACH]35825.IPB[/ATTACH]
[ATTACH]35826.IPB[/ATTACH]
[ATTACH]35827.IPB[/ATTACH]
[ATTACH]35828.IPB[/ATTACH]
[ATTACH]35829.IPB[/ATTACH]
[ATTACH]35830.IPB[/ATTACH]
Cheers Derek
