1-72 Scale Higgins Boat
  • Neil Merryweather
    • Dec 2018
    • 5199
    • London
    [ATTACH]324919[/ATTACH]
    Ok so here is my current build which is really just finishing an old one.The figures are just placed randomly at the moment to get an idea of how it will look.
    [ATTACH]324920[/ATTACH]
    I don’t have any earlier shots than these because I started this years ago, and even though I have only just done the weathering of the LCVP and started painting the figures I hadn’t joined this forum so I wasn’t planning on blogging it.
    [ATTACH]324921[/ATTACH]
    The Higgins Boat is the Airfix one, built out of the box. The figures are a mixture of Revell, Italeri, Hasegawa, Caesar and Pegasus Hobbies. They are quite variable in terms of sculpting quality, even in different sets from the same manufacturer. This was fine, actually, because I wanted to show the GIs being different heights and wearing slight variations in uniform. I also wanted to get across the feeling of them being crammed in against one another, which is something you very rarely see with model figures.
    There is actually rather an inaccurate variety of different uniform styles, in fact some are even paratroops which are completely wrong but I decided not to get too fussy about that.
    Just thought I would drop that in now to stop the rivet counters before they get too excited!
    I knew I would need a to do a lot of dismembering and use figures from different sets because there are very few standing still poses available. I avoided making duplicates because I wanted them all to be individuals. I pinned the bits together with fine wire and used this superglue and plastic primer which I got online.
    To be honest, I don’t know that it is any better than ordinary superglue, given that these are static models and not wargames figures.
    I filled gaps and made the respirator bags and life preservers with Duro green stuff.
    I primed them with Rustoleum plastic primer which was a recommendation on some wargaming website or other. It works fine in that it gives a hard coat to the soft plastic, but when I started painting I discovered I had obscured some of the detail. I should have followed rule number one of spraying- that is that several light coats are preferable to one heavy coat! But I was on a roll and I had no intention of stripping the paint and starting again.
    I started researching the uniform colours and I realised what a minefield it is!
    I did a few tests and discovered that I didn’t have many suitable colours. Being new to brushing with acrylics I found that acrylic paint doesn’t cover very well over white, so I undercoated them all with a brown, to reduce the effect of any gaps in the paint. Maybe that explains why some people prime with black? I also discovered the difference in consistency between Model Colour and Model Air…..
    I found a Vallejo colours list for D-Day GIs on another wargames website so I used that as starting point, but when the new paints arrived I found I didn’t agree with all the choices …. I could have mixed colours myself but I prefer to have ready mixed colours available for touching up if necessary at a later stage.
    I have to say that whist I love the convenience of acrylics with the airbrush, I really don’t like them very much for brush painting. In fact I had such trouble with the fine detail of the webbing that I dug out my old Humbrol enamels, most of which must be over 30 years old!!!
    And still working - after a good stir.
    Back in the day I used to think nothing of painting the eyes on these 1-72 scale boys, but now, even with an optivisor, I find I’m happy with a pink blob where the face is!
    The Higgins boat was primed with Halfords rattle can grey primer (lovely stuff), and I have a feeling that is how I left it… It was before I started the SM55 so must be at least 3 years ago!
    I modulated it just recently with a couple of light greys through the airbrush, then a good coat of Klear before the decals. Another coat of Klear followed by a couple of oil washes, brown and black. And some brown pastel for the rusty bits (it was mostly plywood, so not much rust about).
    I still need to add some details like ropes and fenders and the machine guns.
    And then the big challenge… the water!
    That’s all for now folks!
  • minitnkr
    Charter Rabble member
    • 7551
    • Dayton, OH USA
    Love the crowd. They're close enough you don't notice the paras. I'm strictly a hairy stick painter and use Modelmaster acrylics. They took over PollyS. An excellent brush paint. They cover & level well & the flats are. I work in 1/87 so don't use an AB & am sensitive to the loss of detail. PaulE
      • 15744
      Hi Neil
      Looking very good. I do agree that the crowded look is realistic. I don't think the variety of uniforms matters. Are you planning a base for this?
      • Gary MacKenzie
        SMF Supporter
        • 1057
        • Gary
        • Forres , Moray , Scotland
        https://en.wikipedia.org/wiki/First_...a_and_uniforms << may allow for the mixture of uniforms etc , they landed in landing craft on islands during Operation Dragoon
        • Neil Merryweather
          • Dec 2018
          • 5199
          • London
          Thanks Gary, I'll buy that!
          although the decals are from Omaha......could be the same LCVP went off tho the south of France later?
          BUT
          to answer Jim's question, yes I am planning a watery base, and now I have to decide between the bluish Mediterranean or the greyish, brownish English channel.
          HMMMM....
          • Steve Jones
            • 6615
            A wonderful subject to have focused on. With D Days 75th anniversary coming up you may want to choose the Channel option.
            As you started this project years ago do you find your skills have changed during this time to enable you to revisit and improve the build??
              This looks great Neil:smiling2:.
              I can certainly see a lot of work has gone into this.
              • Neil Merryweather
                • Dec 2018
                • 5199
                • London
                Morning Chaps!
                Ok so the next challenge is the rope fenders as shown below
                [ATTACH]325369[/ATTACH]
                There are none included in the kit but they are seen in almost every picture of an LCVP, and often quite battered, which might be good thing!
                I have been mulling this over for some time and I always thought the solution would be sculpting, as I have some experience with that. I had a go with the green stuff when I was doing the figures and I just was not happy. Admittedly I am less comfy with it than say, Milliput, but the results were not encouraging.
                So then I thought the answer lay in miniature rope-work, using sewing thread or model boat rope.
                Here are the pathetic attempts, and boy, was it painful!
                [ATTACH]325370[/ATTACH]
                So now I’m getting bored and annoyed and my mind is running over anything I can think of that’s ready-made that I can adapt and I think ‘string? – Nah’…’shoelaces? …let’s see what I’ve got’
                I always keep single shoe laces when one breaks, as you never know when they will come in handy, but I must admit I never expected to use them in model making……
                I found 3 contenders, so I soaked each one in thin superglue to seal the weave for painting and to try to reduce the hairiness. The irritating thing about this model for me is the fact that, against my better judgement I used the ‘rope’ from the kit for the ramp winch, and as soon as I painted it all the hairs showed up.
                Now I’ve written that I’m thinking about whether it’s possible to change it at this late stage…
                And on the subject of rope in models, if I had seen a model with rope like in the picture above I would have been very critical, but clearly that is the effect I have to try and replicate .
                Anyway, here are the fender contenders, before and after painting
                [ATTACH]325371[/ATTACH]
                [ATTACH]325372[/ATTACH]
                Actually the middle one is not a shoelace but the cord from a venetian blind. I have no idea why I saved it……
                So that’s as far as I have got. Now I have to figure out a way to close the ends of the weave and add the hanging rope to the top. Maybe it will be fine with the superglue if I just cut it, but I wanted to see which one looked right before going any further. I’ve rejected the one on the left as too chunky, so it’s a toss-up between the other two .
                And looking at this shot the ramp hawser doesn’t look so bad, so maybe I will leave well alone and just FINISH THE DAMN THING!
                And by the way I am planning to do the water thing which I have never done before, so if someone could point me to a few SBS I would be grateful. I notice Mr Spanner’s work has a lot of impressive wet stuff, but the threads I have looked at don’t really mention how it’s done.
                All the best for now
                Neil
                • Neil Merryweather
                  • Dec 2018
                  • 5199
                  • London
                  ooh just realised I owe a couple of replies, sorry about that.
                  Ralph; thanks!
                  Steve; yes, Channel option it is - always was,really.
                  As for the skills thing I think I plateaued quite a while ago....although I guess I learned more about airbrushing in between starting this and coming back to it.
                  I do find every model brings new challenges and lessons learnt. My problem is that I have a rubbish memory so the lessons don't always get retained! The best thing would be to do another similar model using techniques and tricks learned from the previous model-and avoiding the mistakes...
                  But I like variety so I always do something completely different!
                  That said, I have found with sculpting at a particular scale that I get into a groove the more I do. My first 1-72 scale sculpts especially were very difficult, but after the third or fourth I got my eye in, so to speak.
                  I hope that answers your question?
                  N
                    • 22771
                    Just seen this one Neil some very nice work
                      Hi Neil, the boat looks very impressive with all these soldiers crammed into it! The middle fender is the most realistic one if you ask me.
                      DIRK
                        I think the fenders look great Neil:smiling3:.
                        • Andy Belsey
                          • 887
                          Neil,
                          I love all the figures crammed into this. I'll be following now I've found it!
                          My vote for fenders goes with either of the last two.
                          (For discussion purposes only)
                          I just found this on the net, in case it's of help?
                          As for 'Mr Spanner' - I've heard him called all sorts of things, but this is one of the most polite! The others should take note a give him a bit more respect too! I'm sure he can give you lots of tips on water.
                          Andy
                          • Neil Merryweather
                            • Dec 2018
                            • 5199
                            • London
                            Ian, Dirk ,Ralph,
                            thanks very much guys.
                            I know what you mean, Dirk, but it's possibly a bit too chunky. Ideally I would like something in between, but makes me sound like all the architects I work for:confounded:.
                            • Andy Belsey
                              • 887
                              Neil,
                              Thinking about how to 'contain' your fender's thread ends. If there's any nylon, etc in it, you can pass it through a flame quickly. (MR Race is our pyrotechniques expert!) Otherwise superglue or PVA could also work, so long as you don't stop its abillity to take a wash of colour, so use thick glue. There's my penny's worth - hope it helps with your experiments.
                              Andy
