Revell 1/144 Schnellboot Fast Attack Boat.
  • outrunner
    • Apr 2019
    • 2420
    This is my first foray into the world of floaty things, stop laughing at the back, and it's a whole different ball game and I am still not sure if I want to play or not. However, I will try my best and who knows, it might be OK.
    [ATTACH]432691[/ATTACH]
    In the box are the 2 parts for the hull, 2 large sprues with lot of small parts and decals and paper flags and the instructions which are not the best I have seen.
    [ATTACH]432692[/ATTACH]
    [ATTACH]432693[/ATTACH]
    Hull joined up and deck plates dry fitted to test the fit.
    [ATTACH]432694[/ATTACH]
    A bit of superstucture assembled, the railings look a bit oversize to me but I am not going to get involved with aftermarket PE on a practice kit that cost a tenner.
    [ATTACH]432695[/ATTACH]
    Hull bottom painted and some small parts in primer.
    [ATTACH]432696[/ATTACH]
    [ATTACH]432697[/ATTACH]
    I painted the decks with what I thought would be a darkish grey but it looks to have a greenish tone to it so I will have to try something else just using the paints I have to hand, the paint I used was Tamiya RLM Grey.
    [ATTACH]432698[/ATTACH]
    That's it for now and we shall see how it goes.
    Andy.
  • boatman
    • Nov 2018
    • 14451
    • christopher
    • NORFOLK UK
    HI Andy will follow an see how you get on an is this a triple prop sharfts ?
    chris
      • 22770
      A cracking start Andy.
        • 15668
        Hi Andy
        Looks nice. Off to a good start.
        • adt70hk
          • Sep 2019
          • 10400
          Cool!!
            • 18891
            Nice start Andy. The floaty dark side seems to be tempting a lot of guys recently!
            • spanner570
              • 15384
              Andy.
              As Tim suggests, welcome to the 'Dark Side' - and a bit wet too!
              Looking neat. :thumb2:
              • outrunner
                • Apr 2019
                • 2420
                Thanks to all for the positive comments, very encouraging and gives me a reason to try my best with this model. I may have a problem with the rest of the hull paint as I found it hard to get a straight line on a curved surface but hopefully the decals along the side will cover any wobbly bits.
                Chris, if you look again at the hull picture you will see it has four screws.
                Andy.
                • boatman
                  • Nov 2018
                  • 14451
                  • christopher
                  • NORFOLK UK
                  Andy.
                  HI Andy im not well at the moment down with a sick bug but when i looked this morn my eyes were tired from bein up all night an yes i now see what you mean it has 4 props as most have only 3 props so never seen one with that many props before on a small patroll craft i bet i takes off at flank speed wow
                  chris
                  • boatman
                    • Nov 2018
                    • 14451
                    • christopher
                    • NORFOLK UK
                    Andy.
                    YEA GUYS COME ON OVER to the dark side for a change an summit different as me ow m8 Bob has come over so space for more lol
                    chris
                    • minitnkr
                      Charter Rabble member
                      • 7519
                      • Dayton, OH USA
                      Looks fast, bet it turns tight too, any specs?
                      • minitnkr
                        • 7519
                        • Dayton, OH USA
                        46mph is fast.
                          Andy,
                          masking tape is the only way to get really straight waterlines! If the hull isn't too curved, I use wide stuff, but if there are compound curves, I use 2mm tape to define the edge, then back it up with wider tape. The narrower tape will curve much easier. You really have to make sure the tape is well pressed down - even burnished to minimise paint bleeding under. I generally do the upper hull & then mask it & then spray the ( normally ) red lowers. - For some reason, I always have trouble with red!, maybe that's why I 'waterline' a lot of my ship models..
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            Count me in Andy. Interesting build
                            • scottie3158
                              • 14199
                              • Holbeach
                              Andy,
                              I will follow along. I have only ever built two floaty things and that was as a kid. HMS Fearless and the Vosper torpedo boat.
