Landing Craft, Assault — Operation Infatuate I, 1 November 1944 (1:35 Gecko kit)
    Thanks, though it’s slower going than I would like (which is, of course, entirely my own fault ). But by now I’ve made more of the floor and the rear walls of the forward compartments:
    [ATTACH]488903[/ATTACH]
    Gecko has made the “tunnel” far too small, because their version doesn’t “climb” up the sloping floor but is flat together with the centre bench. But because the bench really follows the curve of the main floor, and the tunnel is an extension of the bench, it ends up much further up the sloping floor here than it does in the kit.
    I made that part by cutting an almost-square of plastic card and then cutting a slot for the tunnel down the middle. That way, I didn’t have to work out the size of two triangles for the sides and cut them accurately — I could just build a rectangular block of sides, top and rear to glue into the slot, then fill the gaps that were left.
    Similarly, for the side floors, I glued rectangles to the sides of the sloping floor and stuck floors for the steering shelter and machine gun cockpit on top of those. Their tops need to be at the same height as the tops of the wider parts of the frames here.
    • Neil Merryweather
      • Dec 2018
      • 5210
      • London
      #122
      This is getting truly epic now Jakko!
        • 18959
        Well reasoned changes being made here. It’ll be worth it in the end….
        • The Smythe Meister
          • Jan 2019
          • 6248
          #124
          Blimmin Eck Jakko,
          You should patent this..... it's looking the Dog's already!!
            I certainly hope it’ll be worth it in the end, though I doubt anyone will notice if I don’t show them the photos of the work involved
            Now I need to add a bunch of details like angle iron, rivets, wooden beams and other stuff inside the steering shelter and machine gun cockpit, because trying that once the rear plates are on will be very difficult.
              [ATTACH]489001[/ATTACH][ATTACH]489002[/ATTACH]
              I can only take those rivets in small doses, so this is it for tonight, I think. No idea how Mike ever finished those Centurion bridge sections without going completely mad
              Oh, and I replaced the moulded-on frames because as I mentioned before, Gecko’s are 1 mm too shallow. Easier to cut them off and put a bit of 3 mm strip in their place than to try and make them deeper.
                • 15825
                Yes Neil. Truly epic indeed.
                Not only a great build but very inventive problem solving.
                • Mickc1440
                  • 4786
                  #128
                  The people at Gecko should see this, amazing work Jakko
                    IMHO, they should have seen it before making their kit
                    • scottie3158
                      • 14261
                      • Holbeach
                      #130
                      Jakko,
                      not only is your attention to detail second to none, but it's your problem solving skills that impress.
                        Cheers, I never realised that might impress people, though … I just think about things, try something, and muddle through
                          I’m not overly happy just now:
                          [ATTACH]489045[/ATTACH]
                          When I was building all the stuff from the last photos, I was wondering why the pieces of angle iron with the rivet heads were not up against the hull, but as I was following this photo:
                          [ATTACH]489046[/ATTACH]
                          … I saw no reason to not have it like that. Trying to work out what is supposed to be between them and the hull, I took a close look at the plans, and found there is supposed to be nothing between angle iron and hull …
                          Looking at the photo again, the penny dropped and I realised why there is a gap in the photo: that plank with the metal bracket on it, that I had represented by a piece of plastic card between the angle iron and the hull, is not a plank attached to the inner face of the hull at all Rather, it’s a plank that’s been pushed inward, or maybe the ones above and below have been pushed out …
                          That meant the angle irons and planks had to come out again, and trying to do that, I cut through the thin plastic card I had glued to the front bulkheads to represent the armour plating. This then necessitated taking those off, but they were fully glued to the thicker card I had used to close the openings, so it all had to come out. The small ribs I had added from square rod also turned out to be of a material that’s barely glueable with model cement (I’m guessing it’s HDPS) so they just snapped off and left no more than a glue shadow behind.
                          Dammit.
                          I don’t feel like rebuilding all of this tonight, so I’ll contend myself with filling the scars left by this demolition work and probably continue tomorrow instead
                            • 15825
                            That's a real shame Jakko. It all looked so good. Your ability to interpret these photos has come back to bite you on this occasion. I have no doubt you'll sort it.
                              It’s really just a matter of doing it all again, minus the horizontal planks on the hull sides. The annoyance is at having to do the same work twice, which I don’t enjoy
                                Part of the way there:
                                [ATTACH]489101[/ATTACH]
                                I didn’t add thicker plates behind the armour now, because I went for thicker armour plates I had used 0.13 mm for the first version, but that’s too thin, really — the real thing would be about 0.18 mm thick, and plastic card generally comes in 0.13 mm and 0.25 mm, both of which are about the same amount off, but the 0.25 mm is much stronger.
                                Anyway, I cut pieces to size and added the rivets along the inboard edge. Those are blue because of a comment on another forum, where somebody said I should paint them before cutting them off, to easily tell the domed side from the one that needs to be glued, apparently under the impression I was using moulded rather than punched rivets. That gave me the idea of colouring one side of the plastic I used with a blue marking pen:
                                [ATTACH]489103[/ATTACH]
                                As you can see (if you look carefully) it’s now much easier to spot the rivets that are upside-down.
                                And here’s my rivet spacer in action:
                                [ATTACH]489102[/ATTACH]
