Landing Craft, Assault — Operation Infatuate I, 1 November 1944 (1:35 Gecko kit)
    Also on that drawing, in the list on the right (inside the transverse cross-section), it says “Wood decks Double skin mahogany, top skin ⅜″ laid fore & aft, under skin ¼″ diag.” So maybe that does mean planks rather than plywood, but it certainly tells us there would not be diagonal seams visible on the outside of the deck. The front part of the full-width deck has no seams in any case, being made of 10 lbs (6 mm) DIHT steel plate; only aft of frame 22 is the deck made of wood at all. You can easily spot the end of the steel deck in the side view of drawing 1 because of the strip of wood that covers the seam between the metal and the wood decks.
      • 18959
      This is fascinating. The build differences would not be unexpected between different yards and different interpretations of the drawings. After all, speed was probably more important than absolute fidelity to the design. Strikes me that a huge amount of mahogany must have been used building these.
        I'm of the opinion is was ply, Mahogany would be in short supply esp with having to be imported. Ply would have better stability than two solid planks .
          • 18959
          Maybe, but it was used a great deal on all sorts of construction at the time. Its resistance to impact damage would be far greater than plywood as well.
          • Andy the Sheep
            • Apr 2019
            • 1864
            • Andrea
            • North Eastern Italy
            #50
            Things are getting more and more thrilling :cold-sweat: :upside::tongue-out3:. I'll join the audience being sure I'll learn something new.
              Depending on the thickness of the ply Tim. Would like to find more information on that door, quite an interesting thread.
              • stillp
                • 8106
                • Pete
                • Rugby
                #52
                Any plywood used would obviously have to be a marine grade, the adhesive which was in short supply late in the war. I think if the designers intended ply to be used they'd have said so as well as specifying the grade.
                  • 18959
                  As far as I can tell John, it’s the whole bulkhead. Surprised they didn’t use a native species like Oak though.
                    Fair point Pete.
                    • stillp
                      • 8106
                      • Pete
                      • Rugby
                      #55
                      Here's a landing craft in Battleship Cove, Maryland, which is no help at all!
                      PeteClick image for larger version
                        Yes agree on that Tim, would have made perfect sense.
                        • stillp
                          • 8106
                          • Pete
                          • Rugby
                          #57
                          Shortage of lumberjacks and sawmills, and oak is very prone to expansion and contraction with variable moisture content, so wouldn't work well with an iron frame.
                          Also very slow to season.
                            • 18959
                            What about other species like Ash, Elm (it was still around then), or Beech then Pete…..same problem I suppose….
                            • stillp
                              • 8106
                              • Pete
                              • Rugby
                              #59
                              They'd season quicker than oak, but would still take a year or two.
                              I suspect that most UK boatyards had substantial stock of mahogany at the start of WW2, and they would have been unable to build civvie boats for the duration.
                              The college where I used to work was built in 1952. Most of the furniture was made of Japanese oak, imported as war reparation. In some outside storage there were several mahogany planks, for memory about 30 feet long and three feet wide, six inches thick. Clear and knot-free. They were for the foundry department to cut up for pattern-making! One of our technicians managed to spirit one away to use as a lintel over a picture window in a bungalow he was building in the Rhondda.
                                • 18959
                                Those planks must have been worth a fortune.
                                I’m pretty sure all the benches in my school chemistry labs were topped with mahogany, and they were built in the fifties. I know for certain that the original labs at Porton down (built at the same time, and with at least a couple of miles worth of bench when all added together) were topped with it. All the chairs and stools were made from beech though. The worst bit of this is that as the labs were gradually refurbished in the eighties and beyond the tops and furnishings were scrapped and replaced with more suitable materials. However because of the potential uses they had been subjected to over the years the wood could only be taken off site broken up as firewood. A great deal of it was simple burned on site as I recall.
