Thanks, though it’s slower going than I would like (which is, of course, entirely my own fault
). But by now I’ve made more of the floor and the rear walls of the forward compartments:
[ATTACH]488903[/ATTACH]
Gecko has made the “tunnel” far too small, because their version doesn’t “climb” up the sloping floor but is flat together with the centre bench. But because the bench really follows the curve of the main floor, and the tunnel is an extension of the bench, it ends up much further up the sloping floor here than it does in the kit.
I made that part by cutting an almost-square of plastic card and then cutting a slot for the tunnel down the middle. That way, I didn’t have to work out the size of two triangles for the sides and cut them accurately — I could just build a rectangular block of sides, top and rear to glue into the slot, then fill the gaps that were left.
Similarly, for the side floors, I glued rectangles to the sides of the sloping floor and stuck floors for the steering shelter and machine gun cockpit on top of those. Their tops need to be at the same height as the tops of the wider parts of the frames here.
