Tamiya 1/35 PBR (pibber)
  • JR
    • May 2015
    • 18273
    #61
    Andy nothing wrong to me with the painting, and those figures look ok too.
    Nice looking base, how's the side veneer fixed, glue or double-sided tape . Interested to see how those trees come out .
      • 18890
      Looking very good to me after my catch up. Figures are excellent, great depth of contrast. Libber is going very well also.
      • Andy T
        • Apr 2021
        • 3239
        #63
        Originally posted by Jim R
        Boat looks great. The figures work perfectly. Very interesting to see the base come together - looks neat already. Clever palm trees.
        Thanks Jim. Not sure how the trees will turn out yet but fingers crossed they're not too bad.
        I used tape on this one John. I often use hot glue as the foam is usually a bit wonky without a cutter but this was good enough to try the tape idea.
        Thanks Tim. A couple of hiccups but it's coming together.
        • Andy T
          • Apr 2021
          • 3239
          #64
          Firstly I scored the surface well with a wire brush to help adhesion:
          Then some scultptamold type material from Geek Gaming was mixed with water, pva, and black & brown paint:
          • minitnkr
            Charter Rabble member
            • 7517
            • Dayton, OH USA
            #65
            Will there be a tiger?
              • 15653
              That is a good idea putting the model inside a plastic bag/clingfilm. Which? Looking good.
              • Andy T
                • Apr 2021
                • 3239
                #67
                He's already there Paul, hiding underwater
                Clingfilm Jim. It allowed me to get the filler right up to the hull where I'd not cut the foam very well.
                I've found a decent picture showing the kind of wake I'd like. I just need to try and replicate it now.
                • scottie3158
                  • 14199
                  • Holbeach
                  #68
                  Andy,
                  that looks most bodacious mate. Wabble@ rtfoe did a great SBS on making palm trees a while back.
                  • Andy T
                    • Apr 2021
                    • 3239
                    #69
                    Cheers Paul.
                    Yes I've seen that thanks. Stunning, but maybe a bit ambitious for me.
                    • andy55
                      • Sep 2023
                      • 325
                      #70
                      Great looking model, the tyres are brilliant. It's the details that make it. After using the quick dry modelling clay, I wouldn't touch with a barge pole (but that's personal choice) now it's DIY filler for me (thanks Ron).
                      • Andy T
                        • Apr 2021
                        • 3239
                        #71
                        I've added some random colours to give a bit of variety. It's still a bit damp but once fully dry the plan is to add several layers of gloss varnish with a pinch of red/brown, to smooth out the texture and bring the colours together.
                        I'm still winging it but happy so far
                        • Andy T
                          • Apr 2021
                          • 3239
                          #72
                          I'm not normally superstitious but maybe Friday 13th wasn't the best day to pick. Instead of varnish I brushed on a thin coat of Vallejo still water and after a few hours it has cracked & crazed :tired:
                          I'll see what occurs overnight as it cures fully but some kind of rescue mission is in order!
                          • Neil Merryweather
                            • Dec 2018
                            • 5182
                            • London
                            #73
                            Hmmm not a result you would expect from the name of the product....
                            Fingers crossed Andy
                            • Andy T
                              • Apr 2021
                              • 3239
                              #74
                              Yes, I'm not sure what I've done wrong Neil but it's not happy. The paint had a couple of days to dry before I applied the thinnest layer of still water I could manage, as it warns against building it up thickly.
                              I suppose I should have stuck with many layers of varnish but given the problems I've had with that on this build it wasn't guaranteed to work either lol
                              Looks like I may be scraping or sanding the top layers off and starting again, or maybe trying to fill the cracks. We'll see after some more drying time.
                              These things are sent to try us :smiling3:
                              • adt70hk
                                • Sep 2019
                                • 10400
                                #75
                                Andy
                                Just had a catch-up. The boat has turned out beautifully. Really top drawer. Shame about the water effect..... Hope you're able to fix it.
