Building the IMARA TUG
    Thank you guys. Keep a weatherly eye on the horizon for the next craft approaching
    Andy
      Originally posted by \
      Thanks Ian. I'm sure she will give it some of them feminine touches soon.Cheers
      Andy
        Day 7As i said earlier the instructions are no help and i decided to go it alone. First job was to fit the rails around the sides of the hull, some compound curves meant slotting the rails to get them to fit without snapping the wood this made it form very easily. Once these were in place i had to fit the cross supports and to make sure these were in the correct location i offered in the ply decks and marked off the locations. Next once this was all in place i made up some fillets and additional supports for added strength at the joints. All this was tacked in place with CA and tomorrow i will mix up some resin and hardener and run it around under the edge support strips.
        Fitting the deck ply temp showed up anothe problem... the hull moulding is slightly out of shape across the width and the ply does not fit correctly and has some heafty gaps along the edge, im in two minds as to making new decks or filling in the gaps, i will contemplate this further when i see how much bigger the gap is once the curve of the deck is formed. Just another pitfall of this kit. I dont think i will build another one from this manufacturer.
        [ATTACH]60024.vB[/ATTACH][ATTACH]60025.vB[/ATTACH][ATTACH]60026.vB[/ATTACH][ATTACH]60027.vB[/ATTACH][ATTACH]60028.vB[/ATTACH][ATTACH]60029.vB[/ATTACH][ATTACH]60030.vB[/ATTACH][ATTACH]60031.vB[/ATTACH]
        [ATTACH]60032.vB[/ATTACH]
        Andy
        Hi Andy, agree totally, will not buy another kit from this crowd. The focs'l break on the port side was 1" longer than starboard.
        Began my Imara July 2013, much time spent dressing the "metal" parts. Running a tape round the hull at rail level, port side was longer than starboard. Am at the stage of making and fitting tow rope guards, having fitted windlass and aft capstan.
        • Tugman
          • Feb 2023
          • 62
          #274
          Sky Raider
          I might have come along a bit late on your build but I would like to thank you for your excellent and meticulous job you did on your IMARA.
          IMARA is my favorite model and I call it “The Pinnacle”of all models. I read every comment you entered in this forum and I know that this model can bring lots of hair pulling, but I’m willing to take the challenge and it will be my next model to build.
          I found it on EBay for $550.00 and for that money I grabbed it right away. I’m in the process of selling my home for a larger one where I will have my dream work shop, but I already have started to build a working creadle for the hull.
          Very soon I will post my building log here and all thanks to your efforts in fixing all of the terrible bumps along the way.
          You will be my inspiration.
          Than You
          Julián from Miami
          • boatman
            • Nov 2018
            • 14450
            • christopher
            • NORFOLK UK
            #275
            HI Julian did you look at the date of this thread ?
            chrisb
