Andy thats a shame the deck fit is so off,I'm sure you'll get it sorted tho! Looking great, keep up the awesome work! cheers Trey
Building the IMARA TUG
Hi Andy; I did say the Calder Craft Kits were bad. This might help Model Boat Mayhem Type in imara in the search box, click on one of the photos, then go to the index page. Best of luck mate. Cheers Derek
p.s. if the white metal fittings come in lots of small bags, don't open them until you need them. They are sorted into different areas of the vessel, If you mix them up - BIG PROBLEM
p.p.s Some history, you may be able to track down some original drawings. http://www.clydesite.co.uk/clydebuilt/viewship.asp?id=5913Comment
Day 8
Again i have had to rectify a stupid problem that could have easily been avoided had the manufacturer had a little more common about them. The arm that connected the servo to the rudder was provided with the kit and made from white metal. It advises that a soldering iron is to be held on the brass rudder shaft and solder applied to fix the arm to the shaft. Brilliant idea (NOT!!!!!). If you arent using low melt solder you will find that the arm actually melts before the solder gets hot enough to. What a stupid idea to come up with, conbine that with the fact that its a steering arm that is made from soft metal that can bend easily.
My answer to the problem is indicated in the pics below, i purchased an arm that has a collet and grubscrew and locked it to the shaft with an allen key. Simples.:bangin:
This sorted after throwing away the melted arm and trying to glue a plastic one on with epoxy that also failed i progressed to running a resing strip around the side of the hull to fix the battons in more securely and then moved onto scratch building a stand. Apart from that and the time wasteing excersise nothing more has been done.
[ATTACH]60152.vB[/ATTACH][ATTACH]60153.vB[/ATTACH][ATTACH]60154.vB[/ATTACH][ATTACH]60155.vB[/ATTACH][ATTACH]60151.vB[/ATTACH][ATTACH]60156.vB[/ATTACH]
Andy
[ATTACH]61892.IPB[/ATTACH]
[ATTACH]61893.IPB[/ATTACH]
[ATTACH]61894.IPB[/ATTACH]
[ATTACH]61895.IPB[/ATTACH]
[ATTACH]61896.IPB[/ATTACH]
[ATTACH]61897.IPB[/ATTACH]
Day 9
Next on the list is to smooth out the Bukwarks and get a finish that is something like flat.
[ATTACH]60347.vB[/ATTACH][ATTACH]60348.vB[/ATTACH][ATTACH]60349.vB[/ATTACH]
Using car body filler i put a smear all the way round the bulwarks and will leave to cure before sanding.
[ATTACH]60350.vB[/ATTACH][ATTACH]60351.vB[/ATTACH][ATTACH]60352.vB[/ATTACH]
Andy
[ATTACH]61964.IPB[/ATTACH]
[ATTACH]61965.IPB[/ATTACH]
[ATTACH]61966.IPB[/ATTACH]
[ATTACH]61967.IPB[/ATTACH]
[ATTACH]61968.IPB[/ATTACH]
[ATTACH]61969.IPB[/ATTACH]
Day 10
I have now sanded smooth the bulwarks and i must say they look quite good, i did think of fitting a lining due to the state of them but im happy that i went the filler route now.
[ATTACH]60406.vB[/ATTACH][ATTACH]60407.vB[/ATTACH][ATTACH]60408.vB[/ATTACH]
With this complete its time to look at the first of the white metal parts and fit them in place. I have made a start and will carry on tomorrow. Snow shifting every day has took up valuable time.
[ATTACH]60409.vB[/ATTACH][ATTACH]60410.vB[/ATTACH][ATTACH]60411.vB[/ATTACH][ATTACH]60412.vB[/ATTACH][ATTACH]60413.vB[/ATTACH]
Andy
[ATTACH]62023.IPB[/ATTACH]
[ATTACH]62024.IPB[/ATTACH]
[ATTACH]62025.IPB[/ATTACH]
[ATTACH]62026.IPB[/ATTACH]
[ATTACH]62027.IPB[/ATTACH]
[ATTACH]62028.IPB[/ATTACH]
[ATTACH]62029.IPB[/ATTACH]
[ATTACH]62030.IPB[/ATTACH]
Day 11
I managed to fit the white metal fittings to one side of the hull tonight. I made a cut out for the wash hatches rather than just stick them to the face. A brass rod will be fixed centre of the hatches on the inside of the bulwark to add the scale effect. After i had finished i stood back and realised that i had missed out an hatch, second from the stern. I couldnt leave it until next time as it would have bugged me so i got the dremel out again and fitted it in place.
[ATTACH]60449.vB[/ATTACH][ATTACH]60450.vB[/ATTACH][ATTACH]60451.vB[/ATTACH][ATTACH]60452.vB[/ATTACH][ATTACH]60453.vB[/ATTACH][ATTACH]60454.vB[/ATTACH][ATTACH]60455.vB[/ATTACH][ATTACH]60456.vB[/ATTACH][ATTACH]60457.vB[/ATTACH][ATTACH]60458.vB[/ATTACH][ATTACH]60459.vB[/ATTACH]
Andy
[ATTACH]62065.IPB[/ATTACH]
[ATTACH]62066.IPB[/ATTACH]
[ATTACH]62067.IPB[/ATTACH]
[ATTACH]62068.IPB[/ATTACH]
[ATTACH]62069.IPB[/ATTACH]
[ATTACH]62070.IPB[/ATTACH]
[ATTACH]62071.IPB[/ATTACH]
[ATTACH]62072.IPB[/ATTACH]
[ATTACH]62073.IPB[/ATTACH]
[ATTACH]62074.IPB[/ATTACH]
[ATTACH]62075.IPB[/ATTACH]
Day 12
I have completed the added the white metal parts to the other side today.
[ATTACH]60658.vB[/ATTACH][ATTACH]60659.vB[/ATTACH][ATTACH]60660.vB[/ATTACH]
Andy
[ATTACH]62267.IPB[/ATTACH]
[ATTACH]62268.IPB[/ATTACH]
[ATTACH]62269.IPB[/ATTACH]
Day 13
Great progress today as i was off work for the Easter break. I started to add the electrics in the hull. The motors, speed controllers and switches are now added.
[ATTACH]60661.vB[/ATTACH][ATTACH]60662.vB[/ATTACH][ATTACH]60663.vB[/ATTACH][ATTACH]60664.vB[/ATTACH][ATTACH]60665.vB[/ATTACH][ATTACH]60666.vB[/ATTACH][ATTACH]60667.vB[/ATTACH]
Next job was to add the decks, there is still a lot of in filling to do here but we are almost done below decks now so we will be getting to some decent detailing works soon. Once i have the decks complete i will be moving onto primer stage.
[ATTACH]60668.vB[/ATTACH][ATTACH]60669.vB[/ATTACH][ATTACH]60670.vB[/ATTACH]
Andy
[ATTACH]62270.IPB[/ATTACH]
[ATTACH]62271.IPB[/ATTACH]
[ATTACH]62272.IPB[/ATTACH]
[ATTACH]62273.IPB[/ATTACH]
[ATTACH]62274.IPB[/ATTACH]
[ATTACH]62275.IPB[/ATTACH]
[ATTACH]62276.IPB[/ATTACH]
[ATTACH]62277.IPB[/ATTACH]
[ATTACH]62278.IPB[/ATTACH]
[ATTACH]62279.IPB[/ATTACH]
Looking really good mate.
I take it you're painting all the decking woodwork and not having it dressed and varnished then?Comment
Well you dont waste any time Andy,i thought you were having a break after building the Hunter so this was a nice suprise and shame on me for not noticing this earlier.Looking very nice as well Andy should keep you busy for some time eh,i see that your not happy with some of the kit and read your comment that caldercraft are not very good at producing instruction manuals and things but having never had one of their kits it has come as a bit of a suprise that a company such as them are lacking in certain parts its a shame that we spend alot of money buying these kits only to find inferior fittings and poor instructions as you said in an earlier post a person with lesser skills would have been stumped but glad to see you are cracking on and looks like this will be another educating thread for me anyway (learning things all the time).
cheers steveComment
Originally posted by \Looking really good mate.I take it you're painting all the decking woodwork and not having it dressed and varnished then?
AndyComment
