RNLI WAVENEY CLASS SCOUT 1:12 SCALE
    Day 38
    The final painting on the hull is the 2 red stripes fore and aft. I masked these out and applied several coats of the red. A quick wipe over when dry with white spirits to remove the glue of from the masking tape is needed and then ill add the numbers.
    [ATTACH]73004.IPB[/ATTACH]
    [ATTACH]73005.IPB[/ATTACH]
    [ATTACH]73006.IPB[/ATTACH]
    [ATTACH]73007.IPB[/ATTACH]
    [ATTACH]73008.IPB[/ATTACH]
    [ATTACH]73009.IPB[/ATTACH]
    Andy
      that tape certainly looks good,good purchase mate
      mobear
        Day 39
        Thanks Ole. I have now finished the hull painting and all that's left to do is add a couple of jet outlets at the rear. I have added the ropes to the sides and the black you see at the loops is heat shrink.
        [ATTACH]73056.IPB[/ATTACH]
        [ATTACH]73057.IPB[/ATTACH]
        Andy
        [ATTACH]73058.IPB[/ATTACH]
        [ATTACH]73059.IPB[/ATTACH]
        [ATTACH]73060.IPB[/ATTACH]
        [ATTACH]73061.IPB[/ATTACH]
        [ATTACH]73062.IPB[/ATTACH]
        [ATTACH]73063.IPB[/ATTACH]
          That looks excellent mate, we've got no bloody chance if you join the boat build SIG next year
          That is a nifty idea which I'm stealing for the next build, it'll save making leather straps as I can just paint the shrink .... Lovely jubly ta
            Haha Colin. Ill save my Severn Class until then then mate hehe. The heat shrink works well I just threaded the rope through and run the tip of the soldering iron up and down to shrink it. Glad it helps.
            Andy
              We're sunk then ...... (See what I did there )
                colin `go to ur room`and andy that was a cool idea,and the numbers are defo good,top notch really(was gonna write knotch for the rope thing but thought better of it)lol
                mobear
                  You two are really funny lol, I keeled over laughing haha.
                  Andy
                    What, with no supper again? You're mean! (Or should I say stern )
                      and so i take a BOW(well thankyou very much aaa haaa)
                      mobear
                        Day 40 - 41
                        I have made some progress over the last couple of days. I have managed to fit the fore and aft tread plates and painted the decks. You will also see the jet outlets at the rear. The next thing I decided to do was build the deck hatch at the front. This is meant to be ornate but I have decided that I want to put the power switch and the switch for the radar and lighting in here. To do this I had to make a piece for the base and then cut out a square so that the switches don't have to pass through a double thickness. There are 15 parts that make up this hatch including my extra one. This has had a coat or two of primer ready for the top coat of Orange.
                        [ATTACH]73296.IPB[/ATTACH]
                        [ATTACH]73297.IPB[/ATTACH]
                        [ATTACH]73298.IPB[/ATTACH]
                        [ATTACH]73299.IPB[/ATTACH]
                        Andy
                        [ATTACH]73300.IPB[/ATTACH]
                        [ATTACH]73301.IPB[/ATTACH]
                        [ATTACH]73302.IPB[/ATTACH]
                        [ATTACH]73303.IPB[/ATTACH]
                          you`re doing all this and i`m still lost as to how to make my new boat into rc one,lol.this boat is looking really good though
                          mobear
                            Day 42
                            Cheers Mobear. Today I decided I would construct the tow post. The kit states a tube of 15mm x 120mm but didn't say of what. I looked through the kit and found a wooden dowling at 22mm x 120mm, well that was no good, how could you make a mistake like this. I thought about using some 15mm copper pipe but then there was the need to cap the top off - so I looked around the workshop and found a length of 22mm Aluminium blank that I have. I cut it to length and turned it down in the lathe.
                            I drilled all the necessary holes for the rails etc. by using my dermal pedestal, I have had this a couple of years or more and this is the first time I have used it. Then I fitted the post into the base that I made from the kit as instructed using the 7 parts indicated.
                            [ATTACH]73461.IPB[/ATTACH]
                            [ATTACH]73462.IPB[/ATTACH]
                            [ATTACH]73463.IPB[/ATTACH]
                            [ATTACH]73464.IPB[/ATTACH]
                            [ATTACH]73465.IPB[/ATTACH]
                              Day 42 Cont...
                              The next quick job was to cut a square hole in the forward deck for the switches that go under the hatch, then fit the painted hatch to the deck.
                              [ATTACH]73466.IPB[/ATTACH]
                              [ATTACH]73467.IPB[/ATTACH]
                              [ATTACH]73468.IPB[/ATTACH]
                              [ATTACH]73469.IPB[/ATTACH]
                              Andy
                                this is getting ur `pimp my boat`style and it gives it a bit of Andy workmanship
                                mobear
