HMS King George V - 1/350 Tamiya
    This will be my next project which I will be starting shortly after my HMS Roberts is complete.
    [ATTACH]86771.IPB[/ATTACH]
    [ATTACH]86772.IPB[/ATTACH]
    [ATTACH]86773.IPB[/ATTACH]
    [ATTACH]86774.IPB[/ATTACH]
    [ATTACH]86775.IPB[/ATTACH]
    [ATTACH]86776.IPB[/ATTACH]
    [ATTACH]86777.IPB[/ATTACH]
    [ATTACH]86778.IPB[/ATTACH]
    [ATTACH]86779.IPB[/ATTACH]
    [ATTACH]86780.IPB[/ATTACH]
    [ATTACH]86781.IPB[/ATTACH]
    [ATTACH]86782.IPB[/ATTACH]
    [ATTACH]86783.IPB[/ATTACH]
    [ATTACH]86784.IPB[/ATTACH]
    Cheers Derek
    Wow! Nice one
    You have many complements there Derek !!
    Can I ask if these kind of kits are good...well, high standard quality? Or you need complements for a nice result...? O_o
      Hi Polux, It depends on the manufacturer, HMS Roberts was an OOB construction, if you are thinking of doing a 1/350 Ship I would highly recommend HMS Roberts, it contains everything you need, and since it has a steel deck, no need for the wooden one. On the other hand, HMS King George V is an older kit, but a good kit. However you do not get handrails, and the Cranes are rather poor injection mouldings etc. etc., as you can see I have been using my pocket money over the last few months so that I do the old lady justice.
      Hope this helps.
      Cheers Derek
        Thanks for the info Derek
          • 22770
          I will watch this one Derek been looking forward to you starting
            Will be watching this. Is it my imagination or does the bridge look like the one on the Warspite?
              Thanks for your interest Lads, not an expert on Battleships Graham so can't help, sorry. Just a note to say that I have added this to my purchases, will use this chain for the Anchor Stoppers. Hope to make a start on the kit the end of September. Derek[ATTACH]87612.IPB[/ATTACH]
                Help please, looking at photos of the bow of KGV there are two chains each side which I understand goes down to the Skeg at the bow and is used to deploy Paravanes. Have googled for hours but cannot find a drawing or photo of the deck arrangement terminations for these chains. Any help would be much appreciated. Derek
                • dave
                  • Nov 2012
                  • 1828
                  • Brussels
                  I am not well enough up on the bits to know if it shows what you need, but there are some good stills of the bow of HMS King George V in 1945 on the British Pathe website. http://www.britishpathe.com/video/stills/hms-king-george-v
                    [ATTACH]89932.IPB[/ATTACH]
                    Thanks Dave, I appreciate your efforts, all the photos I have found are either too far away or out of focus, but having trawled the Internet for many more hours, I think I have a grasp of how the Paravane deployment system worked, all I need to do is to show it stowed, see the two lines of small chains amid ships in the photo attached running from the bow. Thanks again for your efforts. Derek
                    • dave
                      • Nov 2012
                      • 1828
                      • Brussels
                      Not a problem Derek, it is one of those sites I browse periodically and I remembered seeing the KGV clip recently.
                        Finally managed some time to get started. The hull is a complete single moulding and the deck comes in three sections.
                        [ATTACH]90025.IPB[/ATTACH]
                        Have drilled out the 3mm and 1.2mm holes and removed the moulded anchor chain. Also removed all the moulded on Winches as the wooden deck kit comes with PE winches.
                        [ATTACH]90026.IPB[/ATTACH]
                        Added some scrap 1 x 2mm evergreen to act as a shear key to assist deck alignment.
                        [ATTACH]90027.IPB[/ATTACH]
                        Fitted the deck with Mr Cement.
                        [ATTACH]90028.IPB[/ATTACH]
                        Plan to add the Paravane equipment to the kit, so purchased some 41 links/inch chain. It looks a but too heavy, but that's as small as I could find, so will have to stick with it. Have added a couple of shots the KGV bow skeg plate where you can see the holes for the chain, and an actual photo of the chain.
                        [ATTACH]90029.IPB[/ATTACH]
                        [ATTACH]90030.IPB[/ATTACH]
                        Cheers Derek
                        [ATTACH]90031.IPB[/ATTACH]
                          Forgot to mention that the middle deck section was a bit too wide so had to trim it slightly to improve the fit. There was only three small areas to be filled between the deck and hull, two where Tamiya had moulded recessed for a location spigot, the recesses were a little too deep and penetrated the deck at the edge. Also the bow section of the deck was slightly too short, so had to fill it in, see first photo below.
                          [ATTACH]90426.IPB[/ATTACH]
                          This week I have been plastic bashing, making up all the deck levels as you can see in the photo below.
                          [ATTACH]90427.IPB[/ATTACH]
                          The remainder of the photos show a dry fit of all the deck levels. Filled in several slots where PE will be used in place of the kit components. Will be carrying on with this work until all of the components are dry fitted.
                          [ATTACH]90428.IPB[/ATTACH]
                          [ATTACH]90429.IPB[/ATTACH]
                          [ATTACH]90430.IPB[/ATTACH]
                          Derek
                            This week made a start on the 5.25" guns. Looking at the kit barrels compared to the brass ones I bought; with hind sight I would have stuck to the kit ones.
                            [ATTACH]90989.IPB[/ATTACH]
                            Anyway, I cut off the barrels, drilled 0.6mm dia. holes and CA glued on the Barrels with the ZAP CA glue, this glue seems to have a stronger bond with plastic than most CA glues and it is highly penetrating.
                            [ATTACH]90990.IPB[/ATTACH]
                            Made up the funnel structure, have still to do the funnel caps. Most models I have seen either just use the kit cap, or hollow out the cap and fit the brass after market ones. I plan to shave off the plastic flush with the cap ring so that some funnel internal detail is left and then fit the brass ones.
                            [ATTACH]90991.IPB[/ATTACH]
                            To me the kit moulded doors and Ladders are perfectly adequate, so rather than replace them with the brass ones, I am going to use the after market brass doors and ladder to enhance the kit.
                            [ATTACH]90992.IPB[/ATTACH]
                            [ATTACH]90993.IPB[/ATTACH]
                            [ATTACH]90994.IPB[/ATTACH]
                            The last two photos shows one of the 5.25" guns enhanced as an example, only 7 more to go.
                            [ATTACH]90996.IPB[/ATTACH]
                            [ATTACH]90997.IPB[/ATTACH]
                            So far everything is still dry fitted.
                            Cheers Derek
                              • 22770
                              Just caught up on this one Derek some great work and it's looking good
