Looking good Steve.Dont forget to add the 'Golden Rivet'!.
The Victory Challenge
Originally posted by \Rivet or divotWouldn't Victory have had a copper plated hull by the early 19th century ?
SteveComment
I've had a first go at painting the hull.
It's a start, there's something to work with but there's a lot to do. I'm using my normal enamel paints so I'll need to leave this for 24 hrs before I start mucking about with it.
I've also got some paint on the sails, with a bit of variety.
These need something else doing to them (apart from painting the yard arms!) but I've not worked out what...yet.
Also painted the masts, again with a bit of variation as it seems unlikely to me that every tree and every varnish was exactly the same.
Some detail painting to be done once they have cured.
SteveComment
Looking very good Steve.
I think the sails could do with some pre and possibly post shading to give varying shades darker at the bottom lighter to the top.
Going to try that with mine once completed ( if you've read my post on my build you will under stand what I mean )Comment
Nice work Steve. I'm in total agreement with you about timber.....It does annoy me when I see pieces of wood on models all stained the same shade. Trees arn't all the same colour inside!
So, top marks for your masts....
I'm on the lookout for a kit , so should join in the fun in a few daysComment
Shading the sails will make them look better, I didn't and they look very unintersiting. Also there are ropes molded into the sails which could be highlightedComment
I am so over the moon people have picked up the challenge! Seeing these great results is motivation to get mine looking better, picking up some great tips on this one!Comment
