VII/41C U-boat
    Have finished painting of the hull. Will leave this a while to cure before other parts are attached and before weathering starts. Parts of the conning tower have been assembled and most primed.[ATTACH]97217.IPB[/ATTACH]
    [ATTACH]97218.IPB[/ATTACH]
    [ATTACH]97219.IPB[/ATTACH]
    • monica
      • Oct 2013
      • 15169
      #32
      the paintwork so far looks great,do wish i could use my AB,like that would real help,
        Thanks. Just use nice things layers to build up the shading.
          looks fantastic so far
            Looking great.
              i would use a plastic primer from any car shop then top coat as this is whats used on plastic pars on cars
              it goes on clear and you can get it in a spray can
                Right...decided to primer the conning tower etc with Vallejo primer (spent money on it, so may as well use it). Left it a whole week to cure...seems to have worked. Had no issues with it this time.
                Have started on the camo work...used Vallejo White Grey for this.
                Conning tower etc has been given a few pre-shading lines with German Dark Grey and then covered with Vallejo Light Grey.
                Once that is cured, i'll start the White Grey camo on these sections.[ATTACH]98113.IPB[/ATTACH]
                [ATTACH]98114.IPB[/ATTACH]
                • monica
                  • Oct 2013
                  • 15169
                  #38
                  looking so good Andrew,real like the shading lines,and good job so far on the camo,
                  • flyjoe180
                    • Jan 2012
                    • 12433
                    • Joe
                    • Earth
                    #39
                    That looks great Andrew, nicely painted.
                      Right...some progress has been made over the weekend. Conning tower has been assembled, sprayed and give a little camouflage detail. Decking has also been painted.
                      Tried a pencil thin camouflage detail but couldn't seem to manage it with my airbrush. The bead/stream/line just wasn't thin enough for my liking. So may try it with a brush.
                      But it slowly coming together. Will paint the various doodads in the conning tower this week...hopefully. [ATTACH]98730.IPB[/ATTACH]
                      [ATTACH]98731.IPB[/ATTACH]
                      [ATTACH]98732.IPB[/ATTACH]
                      [ATTACH]98733.IPB[/ATTACH]
                      [ATTACH]98734.IPB[/ATTACH]
                      [ATTACH]98735.IPB[/ATTACH]
                      [ATTACH]98736.IPB[/ATTACH]
                      • monica
                        • Oct 2013
                        • 15169
                        #41
                        coming along nicely do real like the shades of the camo,
                        • ojays
                          • Oct 2011
                          • 1713
                          #42
                          Looking good, looking forward to the next post.
                          Gregg
                          • spanner570
                            • 15432
                            #43
                            Andrew, the more I see of your great build, the more excited I'm getting about opening the box on my 1/72 VII 41/C U. Boat!
                            This is a great thread to pick up tips and info too....
                            Ron
                              Andrew, the more I see of your great build, the more excited I'm getting about opening the box on my 1/72 VII 41/C U. Boat!This is a great thread to pick up tips and info too....
                              Ron
                              No problem Ron.
                              I haven't come across too many fit problems that a quick rub on a sanding stick hasn't sorted out.
                              The main decking comes in three portions. The aft portion of the deck was warped and when dry fitted on the hull, the end part of it was a good inch higher than the rest of the deck. But got a heat gun to it and gently straightened it out.
                              Bit of filler here and there to cover seam lines etc, but no fault with the kit.
                                Cracking paint job Andrew, some nice rusting and it will be a winner. Derek
