Ships in Bottles?
  • donco
    • Nov 2023
    • 31
    • Don
    • East Sussex
    Ships in Bottles?
    As a change from run of the mill models I thought to re-visit the craft of stuffing a bottle with a ship.
    The last time I did this must have been about seventy years ago, so I sent off for a couple of modern books on the subject only to find that nothing in the way of technique has changed!
    To get the little grey cells working I decided to do a very quick build of a little Thames Sailing Barge, a vessel I'm familiar with. This model was just to see how fine the detail could be modelled, bearing in mind that the masts & spars will need to have small diameter holes drilled through them to allow them to be folded backwards together with all the rigging.
    Here's the result of the "test model" which has taken just over a week of afternoons to get this stage.
Name:	Minibarge WIP_2.jpg
    The hull is 62mm long and I have, at least, proved that it's doable for me to drill little holes through little bits of wood!
    Incidentally, the Admiralty Pattern anchor is from three pieces of 28g steel wire silver soldered! It's 3/16" high. I have yet to add flukes.
Name:	Admiralty Pattern.jpg
    Now to find a bottle into which I intend to erect a 5" long "Endeavour" of Shackleton fame. Watch this space?
  • HAWKERHUNTER
    • Feb 2012
    • 1504
    • Steve
    • Halifax, West Yorks.
    What an interesting subject Don. Considering the size of your model I think you have made a cracking job of it. Following with interest.
      • 15606
      Watching with interest. When I was very young one of my dad's relatives, can't remember who, had a ship in a bottle on his mantlepiece. We visited a couple of times and as a 4 or 5 year old I still remember being intrigued by it.
      • Neil Merryweather
        • Dec 2018
        • 5167
        • London
        Much respect sir!
        • Richard48
          • 1883
          • Richard
          • Clacton on Sea
          As Neil says much respect.Awe inspiring work.
          • donco
            • Nov 2023
            • 31
            • Don
            • East Sussex
            Thank you for your kind words, Fellers! A heavy frost this morning dictates a day in the shed! So.... It's time for a start on the "Endurance" I'll try to document the build , mainly for my own archive of model making but some pix can be posted here.
            • stillp
              • 8082
              • Pete
              • Rugby
              I hope you have a heater in the shed!
              • donco
                • Nov 2023
                • 31
                • Don
                • East Sussex
                Yes, Pete. I do have a heater but with the winter fuel allowance now kaput it's set to low - so still a little chilly. Yesterday I blocked out the hull of the "Endurance" - henceforth referred to as the model! - and plotted the side and bottom shapes using thin card templates.
ID:	1241268 Deck view
ID:	1241269 Bottom view ...
                ...and this morning finished shaping the basic hull and mounted it onto the building jig.
ID:	1241270 on the build jig
ID:	1241272 a close up.
                Now to paint the hull ready to add the deck layer, bulwarks, various strakes & wales, deck houses etc.
                That's all for today.
                • donco
                  • Nov 2023
                  • 31
                  • Don
                  • East Sussex
                  I needed to reduce the depth of the hull so that it will fit through the neck of the bottle! A 1/64" plywood deck layer was added after scribing some planking, tinted with soft pencil lead rubbed in. The bulwarks are from the same plywood CA'd edge on. Hull now painted Black acrylic and when dry a couple of coats of shellac was brushed on.
                  Bowsprit is added, hardened with thin CA, sanded and drilled for running threads which will raise the masts.
                  Here's the result of another afternoon in the shed. Next will be to add the deck structures - apparently mostly dog kennels I understand!
ID:	1241577 Click image for larger version
                  • Steven000
                    Steven000 commented
                    Editing a comment
                    Lovely woodwork Don! Looks great ?
                  • 15606
                  This is a real example of superb small scale modelling. Looking forward to the next steps.
                  • donco
                    • Nov 2023
                    • 31
                    • Don
                    • East Sussex
                    Yesterday I put a few notional deck houses and fittings in place. Today, Sunday morning in the shed with a reel of fly tie silk and and a bit of breath holding, I've braced the mizzen mast with it's lower shrouds.
Name:	mizzen shrouds.jpg
                    The engine room ventilators are 'large' insect mounting pins with the round heads filed flat on one side, clipped short, painted White with Red 'insides' and CA'd into drilled holes.
                    • pjgtech
                      • Dec 2023
                      • 741
                      • Peter
                      • Swale Kent UK
                      Wow, attention to detail is summit else, looks fab so far.....
                      • donco
                        • Nov 2023
                        • 31
                        • Don
                        • East Sussex
                        Thanks Peter! It's now 4.15 and I'm finished with the shed for today. All of the lower shrouds are on.
                        The sheer batons are from black cotton stiffened with CA. Incidentally, the thick Black continuous cordage from stern to bow is there as a temporary 'hand' to keep the masts in their correct fore & aft relationship. It's ordinary Black sewing cotton but looks thick & hair under so much magnification! To give some idea of sizes, this view on the screen of my laptop, shows the model at Full Size! That is from stern to bow measures 4.25 in. The five small companion ways are 3/32 " square.
                        • scottie3158
                          • 14189
                          • Holbeach
                          Excellent modelling.
                            • 15606
                            Great looking little ship.
