starting with the bowsprit mast was painted & the spars were added 1st with Tamiya liquid cement and once this was dried, I actually tied the spars onto the mast using thread then I need the ratlines and finally, foot ropes which were used so that the crew could get out onto the spars to furl & unfurl the sails
this was repeated for all the remaining masts Took approximately two weeks to complete, hence the lack of any postings
You can also see I had to do a repair on one of the spars on the bowsprit hence the piece of wood on the end
other photo show the construction of the binding for the bowsprit which attached to the very forward end of the ship normally, this would form a figure of a loop around the end of the bowsprit I’m loop back around from the Forward end of the ship but because of the way they’ve already started the construction on this the small front deck was already in place and I didn’t want to remove it with a fear of breaking it or other damaging it some other way so what I did was I got two pieces of Dowel with a gap in between to make the binding, which is then looped over the end of the bowsprit and pushed inside the ship to make it look like it had actually been looped around
