Original 1960’s Airfix HMS Prince
  • Bigfoot57
    • Jun 2015
    • 1101
    So I brought this off eBay as a partly constructed model as the person had lost interest in it & what they had done was used Airfix enamel paint and glue and looking at the paints are supplied with the model. these also date back to the 1960s Well when I got it. It was not very well made and I’ve had to deconstruct it from scratch soaking in a bowl of water overnight I don’t know if that helped or not
    Click image for larger version  Name:	IMG_2909.jpg Views:	0 Size:	263.8 KB ID:	1246674 Click image for larger version  Name:	IMG_2899.jpg Views:	0 Size:	205.6 KB ID:	1246675 Click image for larger version  Name:	IMG_2908.jpg Views:	0 Size:	234.4 KB ID:	1246676 Click image for larger version  Name:	IMG_2924.jpg Views:	0 Size:	409.2 KB ID:	1246677 Click image for larger version  Name:	IMG_2925.jpg Views:	0 Size:	450.8 KB ID:	1246678 Basically we had a few broken parts which need to be sorted out in the course of building it as you can see, the keel taken a bit of a battering as well, so that’s gonna need sorting so far I’ve given the hull sides a complete repaint they’re now ready for the gilding to be added
    been a long time since I constructed a ship of the line so this will be a learning curve for me as well so this is a rare kit. I do not want to screw this one up
  • PaulTRose
    • Jun 2013
    • 6466
    • Tattooine
    Good luck
    Id like to this go together....proper classic
    Per Ardua
      • 15705
      These Airfix kits of sailing ships are very good for their time. Looks like yours is the 1968 boxing so the moulds were quite new so parts should be better than the much later reissues. It will be an interesting build
      • Bigfoot57
        • Jun 2015
        • 1101
        Click image for larger version  Name:	IMG_2926.jpg Views:	0 Size:	474.2 KB ID:	1247770 Click image for larger version  Name:	IMG_2946.jpg Views:	0 Size:	389.7 KB ID:	1247769 Click image for larger version  Name:	IMG_3034.jpg Views:	0 Size:	375.4 KB ID:	1247768 so when I last posted something I just painted the hull sides and was ready for the detailing before assembling
        1st up I painted all the pieces Black silk matt using revelle aqueous acrylic paint
        Then using a metallic gold pen from Ghaleri added all the gold and finally painted the windows in blue whether that is correct I couldn’t say as glass usually reflects some of the sky colour when on the outside anyway here’s some pictures
        • Bigfoot57
          • Jun 2015
          • 1101
          Click image for larger version  Name:	IMG_3038.jpg Views:	0 Size:	345.9 KB ID:	1247772 Click image for larger version  Name:	IMG_3035.jpg Views:	0 Size:	305.8 KB ID:	1247773 Click image for larger version  Name:	IMG_3037.jpg Views:	0 Size:	410.8 KB ID:	1247774 Click image for larger version  Name:	IMG_3033.jpg Views:	0 Size:	327.5 KB ID:	1247776 Click image for larger version  Name:	IMG_3041.jpg Views:	0 Size:	249.4 KB ID:	1247775 After that was done it was time to put the thing together. The only problem I had was the transom at the back wouldn’t fit correctly at the bottom so I had to do some slight modifications to the back. It’s now all fitted together along with the deck and the next stage will be to add all the deck detail The elastic bands were used to secure the front and back of the ship as those had a tendency to keep springing off and needed securing whilst the glue set the rear transom was easy. I could just wrap the elastic band around it and on a part of the models sides where there is a step in the deck levels, but the front one there was nothing to hold the band too so I stuck a coffee stirrer through two of the gun ports and did it that way
          The final picture shows some 1 mm diameter strips which I’m going to attempt to make a wooden deck with no idea how this is gonna come out but we’ll see you can also see that I cleaned up the paintwork a bit and generally tidied up ready for the next section which will be the deck furniture
          • PaulTRose
            • Jun 2013
            • 6466
            • Tattooine
            Thats going to look brilliant when its done
            Per Ardua
              • 15705
              What a great job you're doing with this. Looks very good. All the gold really sets this model apart.
                • 18907
                That’s looking very good. Loads of gingerbread on it isn’t there ?
                • Bigfoot57
                  • Jun 2015
                  • 1101
ID:	1248481 Click image for larger version
ID:	1248482 Click image for larger version
ID:	1248483 Click image for larger version
ID:	1248484 Click image for larger version
ID:	1248485 Click image for larger version
ID:	1248486 Click image for larger version
ID:	1248488 Click image for larger version
ID:	1248489 Click image for larger version
ID:	1248490 Click image for larger version
ID:	1248493 Click image for larger version
ID:	1248494 Right having painted the transom, I then set about cleaning up the paint work and that unicorn which I was not happy with at all after that it was time to do some repair jobs for some reason the person who had this previously had stuck the windless or the capstan onto the rudder and it was missing three of its handles as well why they did that I have no idea anyway using that 1 mm wooden strip I fashioned three new handles for said Capstan painted it then mounted it in its correct position on the deck next were all the companion ways and stairways along the sides of the ship
                  Next was the cannons the previous owner had stuck them on the wrong way round then i had to fashion some roof covers for the culvers as these were missing completely and I also had to make a replacement gun carriage as that was also missing Click image for larger version
                  I then cleaned up the lifeboats as one of them had a load of glue in the bottom of it and I’ve now painted the gun carriages and the guns ready for mounting on the deck i’ve also made a couple of racks for the lifeboats to stand on as they just can’t be stuck just to the deck I would presume that they have some sort of support that they rest in
                  • rtfoe
                    • 9086
                    Wow, nostalgia just hit me. I remember getting this kit for Christmas and didn't remember the rest of Christmas day just sat and built it and finished it the next morning. I don't do that anymore.?
                    Looking good and what a find.
                    Wabble
                    • Bigfoot57
                      • Jun 2015
                      • 1101
                      Casting Replacement Resin Parts
                      As there were numerous parts missing from this kit I have now purchased a resin casting kit to make replacement parts using those I do have as a template
                      This was constructed from something called Bluestuff cause that what it looks like you add boiling water to it and it becomes pliable you can then press things into to make a mould impression leave for an hour remove the item you pressed into it and then you pour in your resin mixture leave it for 24 hours and hopefully you should have resin replacement you can add pigment into the resin mixture if you want it coloured which I didn’t do as I need specific colours and I don’t know how resin would react to arcylic paint so I just went for clear
                      As you can it looks like it worked so much so I’ve abandon my home made gun carriage and gone for a resin replacement instead the last picture shows a replacement Cathead as this was missing from the kit once painted it should resemble the kit part as normalClick image for larger version  Name:	IMG_3194.jpg Views:	0 Size:	254.2 KB ID:	1248849 Click image for larger version  Name:	IMG_3196.jpg Views:	0 Size:	326.6 KB ID:	1248850 Click image for larger version  Name:	IMG_3195.jpg Views:	0 Size:	190.1 KB ID:	1248851 Click image for larger version  Name:	IMG_3202.jpg Views:	0 Size:	486.7 KB ID:	1248852 Click image for larger version  Name:	IMG_3214.jpg Views:	0 Size:	144.8 KB ID:	1248853 Click image for larger version  Name:	IMG_3218.jpg Views:	0 Size:	184.9 KB ID:	1248848 Click image for larger version  Name:	IMG_3221.jpg Views:	0 Size:	148.1 KB ID:	1248854
                      • Bigfoot57
                        • Jun 2015
                        • 1101
                        Click image for larger version  Name:	IMG_3255.jpg Views:	1 Size:	223.7 KB ID:	1248880 Click image for larger version  Name:	IMG_3256.jpg Views:	1 Size:	117.4 KB ID:	1248879 so after the last piece of resin pouring I now have all the parts necessary to complete this model. They just need glueing together and painting and then adding to the ship as and when they are required The first picture shows all the parts namely two cat heads one bulkhead stairwell 2 large gun carriages and one small one a replacement lantern as one was totally missing 2 cannons 1 large 1 small and the three parts that make up the admirals entrance which is the front the top and the side the second picture is a close-up of the admirals entrance after it’s been painted
                        • Bigfoot57
                          • Jun 2015
                          • 1101
ID:	1249441 Click image for larger version
ID:	1249440 Click image for larger version
ID:	1249439 Click image for larger version
ID:	1249438 After finishing moulding the missing parts I’ve moved back onto the deck and decided to frame the hatches whether this is correct or not I cannot say but I think it makes the model look better so I’ve done it anyway there are two before shots and two after shots can somebody explain why the photos always appear before the text and they don’t appear in the sequence? I upload them in you should’ve had the two before at the top and the two afters at the bottom not the other way round
                          • Bigfoot57
                            • Jun 2015
                            • 1101
                            My latest update from HMS Prince have now added rowing boats along with the oars all the cannons and the Gunport lids the two spare spars and the replacement cat heads which I moulded myself cleaned up the guilding
                            I’ve done the first round of cleanup on the Gunport lids I also mounted the model on it stand as well so it’s very nearly ready to start the masts and then finally the rigging although I think I may have to get some scale blocks to do the rigging justice and the dead eyes look a bit worse for wear as well but considering this was a total wreck when I brought it off eBay I think it’s coming out quite well
                            Click image for larger version  Name:	IMG_3453.jpg Views:	0 Size:	379.2 KB ID:	1250521
                            You may only view thumbnails in this gallery. This gallery has 1 photos.
                            • Bigfoot57
                              • Jun 2015
                              • 1101
ID:	1250817 Click image for larger version
ID:	1250818 Click image for larger version
ID:	1250819 Next up are Click image for larger version
ID:	1250816 the anchors which again are wrong whoever built these didn’t put them together correctly as you can see there’s a gap at the top and they don’t fit at the bottom where the shank joins the beam so I had to use Tomiya extra thin cement to loosen the old cement pull the shanks out clean them up and replace them into the where they should go in the correct position,
                              I destroyed one of the rings completely so I’ve made a replacement one out of 1 mm brass wire and painted it. I’ve also threaded through a piece of what should be reasonable scaled anchor rope once looped through the anchors and the anchors are secured in place on the dead eyes I will clean up all the frayed bits of string hanging off of the anchor ropes secure the ends using cotton to simulate thinner ropes
