DKM Scharnhorst 1943 - 1/350 Dragon Kit + extras
    Originally posted by \
    Cool, I'm gonna need all the help I can get - I've just seen the tool clamps on my Dragon Marder iii, smaller than a gnat's baw hair!
    Hi John.I use a good PVA to attach all my PE these day's Yes it takes a bit longer to dry but you get that bit of extra time to place piece's.And any excess can be wiped away with a damp brush.
      And it doesn't break off easily?
        No it does not.
        I have found that it gives a better bond than CA(for me personally).
        But like any join with certain glues it is possible to come off.
        Once undercoated the bond is even better because the paint also holds it.
          Is is easy to keep clean, Stona mentioned in my other post that acetone is quite useful to keep them clean!
          Hi John, was in Asda at the beginning of the week and bought a bottle of nail varnish remover 'Cutex' with acetone; it does help clean the tools. I also had a small plastic container with dried up CA in it, so I dunked it in a glass jar with the Cutex, left it for half a day and it softened the CA into a thick gunge which I dug out with a screw driver. Was able to clean the container as good as new. So a good tip from Stona. Derek
            This week I have been trying to finish the PE on the superstructure. In the photos below the Superstructure is still loose from the deck, and the forward Superstructure is loose from the Boat Deck, I think it will be easier to paint if I leave them separate.
            On the uppermost platform on the fwd. Superstructure under the Radar, I have added some wire braces to each of the four Yards, this is not on the kit but appears on the box art and on photos of Scharnhorst. These yards are very slender, and probably would not survive the rigging without these braces.
            In Detail 8, I have replaced the kit part numbers MC38 with some 0.75mm round Evergreen, as these parts look ridiculously small.
            I will now be moving onto the ancillary fittings i.e. Cranes, Reels, Ships Boats etc. and finally the Masts.
            Derek
            • spanner570
              • 15482
              #111
              One crazy man, but beautiful work!
                Coming along greatly.
                • peterairfix
                  • Jul 2012
                  • 11088
                  #113
                  I am looking on in awe
                  • flyjoe180
                    • Jan 2012
                    • 12483
                    • Joe
                    • Earth
                    #114
                    Amazing work Derek.
                      Thanks for the positive comments Lads, it is much appreciated.
                      Neither the kit nor the PE aftermarket provide handrails around the aft Range Finders so I have added some from my spares box.
                      Have made up and fitted the lower section of the aft Mast. I found it easier to fit the three platforms first to the loose mast, then the handrails and finally the ladders before fitting to the superstructure with the two braces. The upper mast sections are ready to fit at a later date.
                      Unlike the KGV kit where the breakwaters, bollards, fairleaders, skylights etc. were moulded as part of the deck, on the Scharnhorst all of these have to be fitted individually.
                      Derek
                      • takeslousyphotos
                        • Apr 2013
                        • 3900
                        #116
                        That is superb work Derek......When I try PE all I mange to do is stick either the tweezers to it or my fingers together....... So the nail varnish thing is probably a good idea.
                          HELP PLEASE
                          Was trawling the internet doing my research on this vessel, and saw a model of the Scharnhorst with the Turret tops painted Red. Did some more research and found that two German Destroyers had been accidentally sunk by the Luftwaffe; following these incidents it became standard procedure for Capital Ships to paint their Turret Tops either Red or Yellow when the vessels entered waters patrolled by the Luftwaffe in order to prevent a repeat. I am guessing that the Swastikas fitted on the Fore and Aft decks were also part of this temporary identification procedure.
                          Question: - Can anyone confirm that the Swastikas were only present when the Turrets were painted Red/Yellow. I am pretty sure they were, can't think the Germans would provide 'bulls eyes' for the RAF/Fleet Air Arms.
                          you are correct the swastika was covered when in open sea. It is documented that Bismarck had her identification marks painted out while in Norway before heading to the Atlantic. that paint has now weather away leaving the swastika clearly on show on the wreck.
                          Jase
                            very nice build so far keep the pics coming
                            • flyjoe180
                              • Jan 2012
                              • 12483
                              • Joe
                              • Earth
                              #119
                              Wow Derek, much respect for the work you're doing with this.
                              • geegad
                                • Mar 2010
                                • 2329
                                #120
                                another cracking update
