Jim you jammy so and so what a great kit plank on bulkhead build are great, make sure you keep everything square and all the bulkheads in alignment, what did you pay for it, I am soooooooooo jealous.
OK ken but the pins are under neath the planks, the decks are just glued down over the top, and in stead of ordinary glue I'm using gorilla wood glue holding time of 10mintues to 20 mintues and it does hold but service drying time 24 hrs cost £5 from b&q
Referring to this jimhttp://www.scale-models.co.uk/attachments/wp_20151111_18_28_18_pro-jpg.136745/ they are definitely not under the planks, and actually not to scale if I may say, also check the instructions I'm not sure that you would have found any planks long enough to run the length of the deck as you have them also I'm not sure they would curve as you have them, I would imagine they would be the same as the ones you put on the stern, they would be straight and not follow the curve of the hull. Sorry if I seem to be getting on at you but I think you have an awesome kit there and I would love for you to do a great job of it.
hi ken that's how the kit was cut out in sections and I did make sure all the parts were level across the top and at 90 degree angle to the keel and it just started curving that way when I started pining it :P
I will. By the way ken I have got gloss varnish which I brought for the paddle steamer will it hold stick to water based paint as the instruction said to use water based paint to paint the hull and then varnish it afterwoods but the instructions said nothing about which varnish to use.
