I have just been looking through your build and some marveless work going into it and would I be right in guessing this is 1\96 scale as there seems to be a lot of similarities to my 1\96 cutty sark witch I have resumed with a totally new ship as the old one was beyond repair.
Hi all here is the next update I noticed a split in the vac form mizzen sail and was going to patch it with a stitched square then thought I would experiment with some super glue.
Unfortunately the superglue made the weathering go white but a coat of acrylic white and you would never know.
I've finished all the ratlines on the forecast
Hi all well this is shelved again for a while I've broken the (I don't know what it's called) the bit that tensions the bowsprit, I'm not actually sure how to fix it as it's very thin plastic and superglue doesn't seem to work I'm so annoyed at my clumsiness, this is the fourth time I've broken something on this kit. I will fix it, it's just annoying.
