Looking at the pics I think I need to dirty up the blue a bit, it looks much to clean against the hull(either that or clean the hull up) although like like the hull how it looks.xx
Hi all here is the next update, 12 of the lower deck cannons, not done much detail work on the carriages as they wont be seen, and done some of the deck furniture, next job to drill the holes out for the gun door ropes( that is going to take some time 104 guns X 2 208 holes then I have to try and think of a way to make the rings for the gun port doors for the ropes to go through.
Hi all here is tonights bit, I've corrected another flaw of this kit There is a big gap in the knee of the head (which according to the experts would not hold the weight of the head and should have been filled with carvings of some sort ) here is the gap
and (since i'm no carver her is my fix, I know its not very elaborate but it fills the hole)
