Heller Soliel Royal
    they can be tedious little so and so's ken , your doing a good job though mate
      Hi all well i know I've not touched this for a while, Pam just snapped the fore mast, apparently she was just getting the dog a treat  (the bag with the treats in was on the table with the kit) my fault entirely, she is so upset I'm more cross she even tried to, that's what I'm here for to get stuff, trouble is she thinks because she can make it to the loo and make a cuppa she can do anything, I love her to bits and can't wait for her to get better. Anyway when I do get back on this that will be the first thing for me to takle.
        Right after some good advice I may well get started back on this, I've just bought these 3 books
        So hopefully after a good read the rigging won't be sooooo scarey.
          I really liked lennard peterssen 's book , it's more for English rigging , but very easy to read ,
            Hi all guess what, it was bound to happen a guy on another forum just contacted me. He bought this kit in an auction for a bargain price, after seeing this build and guess what he has 2 of the same hull pices, luckily for him theyre starbord so i will be sending him my spare half. Whoever bought it first obviously gave up on heller so put it up for auction to try and recupe some money.
              Hi all well I'm back on this but with a change of attack, it's now going to be a water line model, I didn't like the ships boats on the deck (take up too much space and I don't believe the ship would have operated like that) so it will be towed along side something like this.
                this should look special ken , don't think I have seen a waterline version of the soleil done before .
                  Hi all well I've detailed up one of the ships boats (I suppose that means I will have to do the other one now)here's the before
                  Put the bathroom sealant on and started painting the tops of the waves
                  Loads more wave painting to do.
                  I've removed a couple of the guns to load the supplies into I understand they used some sort of pulley system from the spars to load the supplies with and I want to depict that has anyone got any detailed drawings of how this was achieved.
                  I've only used one of the port and starboard anchors, I'm hoping the other two are spares, I can't imagine they used all 4 anchors or am I wrong.
                    Hi all well I've finally finished painting the waved (That's a lot of water) not sure if it needs more colour, I'm trying for the dark brackish water of a harbour.
                      that look's awesome ken , can't wait for more .
                        all well I've fixed the foremast and strengthened it with a rod up the middle, making it a waterline model had an unexpected problem to it the main mast locates in an I shaped piece which is glued to the bottom of the hull to keep the mast central and true since I cut the bottom of the hull off obviously that locating area was no longer there also the mast was a lot higher than it should have been, luckily I still had the bottom of the hull that I cut off so I put the mast in it laid a rule across the hull and marked where it cam on the mast and cut that piece off but the mast is tapered at the bottom and the holes through the decks must be the same size as when I put the mast in it Leaned either way so I had a cunning idea and wrapped masking tape round the bottom of the mast till it was a snug fit in the bottom hole ( only problem now is the mast seems to lean sternwards) so now I just have that problem to sort and of course to make sure it is square with the center line as well.
                        • dave
                          • Nov 2012
                          • 1828
                          • Brussels
                          #117
                          Looking good
                          • Bugatti Fan
                            • Mar 2018
                            • 314
                            #118
                            This will be one hell of an impressive model when finished!
                            • monica
                              • Oct 2013
                              • 15169
                              #119
                              looking good,real like the base you have done for it,:smiling:
                                Hi all well I've got this back out as Gandale (Alan on another forum posted an easy way to do the stays on this) (That's what's been scaring me from continuing this build) baring in mind this is my first attempt at doing them I'm quite chuffed with the result (obviously I've seen them done millions of times better but hey I can only get better from now on)
