Dragon 350 Scale Uss Princeton
    This will be a slow for me build got the kit and photo etch from Eduard last year I usually do aircraft or small ships I have made a start got the hull together and all the internal hanger deck detail the front lift is partially raised so I did some detail work on the underside just been fitting the catwalks to the side of the deck later I'll fit the catwalk supports some of the main once are included but I'll have to scratch the finer stuff don't want to go above flight deck height yet as I plan on marking the hull paint demarcation by turning upside down and using a scribing block with a very thin pen fitted to it
    I'm using tamiya acrylics throughout I'll do a bit of weathering but not much any comments or advice most welcome
    Roger
    Done quite a lot in the last couple of days just fitted funnels and island all gone well except the fit of the funnels but that might have been me getting parts mixed as dragon instructions aren't the easiest to follow next up loads of pe railings etc
      • 22788
      Just seen this one Roger and a great start
        Thanks it's going very quickly because I'm off work till Monday it's a big model for me and I'm struggling with order of build at some point I'll have to mask the deck and airbrush the white lines might do that next
        Roger
          Looking good Roger, not many Aircraft Carrier builds about so will be interested to so how it goes. Derek
            Thanks Derek I do love these 350 scale ship kits just wish I could get the paintwork in the correct order I find I'm forever masking spent about 5 hours yesterday just on the catwalks each side of the flight deck
            I was going to do this in splinter camo but chickened out so I'll save that for my hms warspite build
              Spent all day so far building guns the kit includes some pe for the seats and sights and the extra Eduard set includes the chequer plate and rails not going to fit the hand winders I don't think well I'll give it a go
                Painted all the big guns just got a bunch of single barrel guns to build I airbrushed tamiya xf19 then picked out the recoil springs with xf84 then dry brushed xf 54 I'm very pleased with the result
                Roger
                  Just finished the yellow lines on the deck took four hours to mask and ten mins to paint I airbrushed deck colour first to stop paint creep and it worked very well
                    Very neat PE Roger, keep up the good work. You have probably found that shipbuilding on this forum is a lonely road. Derek
                      Yes it is lonely but what the heck it's a fun drive I really do like the 350th scale ships I want to do an Essex class carrier soon but trumpeter one has a very inaccurate hull shape
                        Done most of the railings and built the crane still loads more to do next up fit all the ammo racks for the quad gun at rear and the twin guns on the catwalks
                        I have built all the single barrel orlikon guns 22 in total so far the carpet monster hasn't been hungry
                          Just finished assembling the Orlikon single barrel weapons very small and fiddly
                          Roger
                            Roger
                              Having trouble uploading photos when I do a post
