trumpeter s_100 class schnellboot
    Hi guys this has to be the smallest ship kit it's 350 scale and is only 3.75 inches long
    I made the case from some scrap acrylic sheet and the base is made from some resin type model board we use at work I coated the top with dark blue and green stipled on then when dry coated it in devcon epoxy glue later I'll add the foaming sea spray after the boat is attached
    Still to do all the deck detail ie guns and railings all comments welcome
    Roger
    That looks amazing Roger, love it!
      Thanks it's a bit different from my last build an aircraft carrier lol
      Roger
        Just discovered how good lifecolor acrylics brush on two light coats and they flat out and look as though it's been airbrushed
        I have only used tamiya before these are a lot easier just my opinion
        Roger
          This looks great.
          Will be following.
            Nearly done I'll post pictures when the latest coat has dried
            • Pikeman
              • Feb 2016
              • 1312
              Roger
              Looking good mate and I will also be following the build.
                • 22771
                It is tiny Roger, but your doing a great job on it so far
                  Thanks guys I'll post finished model within ten minutes thanks again for following this very quick build
                  Roger
