Academy 1/350 USS Indianapolis
    My next project is Academy's USS Indiamapolis with Ponto photo etch.  Here are the sprue shots
    I have made a start on the hull.  The pipe on the side is a fuel pipe for the aircraft it carries
      The hull and send are ready to paint.   I have removed the bollards and vents, as they will be replaced by photo etch
        A bit of work on the metal decks that come part of the photo etch and spraying the hull
        The first coat of the blue.  Didn't bother to mask the red part as when I spray the red, you get a graduation in the red colour
        The deck plates painted blue with the anti-slip pattern in black.  Unfortunately, as I was taking the mask off one piece, half the paint came off with it, so I am havingto redo this piece
        The deck witht he masks.  The piece that I have had to redo is top row, 2nd from right.
        • flyjoe180
          • Jan 2012
          • 12400
          • Joe
          • Earth
          Nice work so far Graham, looks good.
            Nice work so far.
              Here is the latest update.  I have finished painting the hull and added a little bit on rust, where the anchor and anchor chain will go and added the wooden deck.  BTW I haven't hijacked this thread, it's just that I have found my old login and am using this from now on.
              This is the first bit of superstructure with the brass added.
                This one is starting to get interesting.
                  nice work mate, the brass and metal parts look interesting, looking forward to the finished product
                    The bits placed before painting.  I bought some solder paste and soldered the bits onto their bases.  It give a very strong join.  Still need to use cyno on smaller bits.
                    The bits burnished before painting.  The lighter bits around the join is the solder.
                    The main guns with brass barrels.  The barrels have been burnished.
                      A little bit of an update, I have made 2 of 8 20mm oerlikon.  Each one take about 1 hour to make.  I normally use a telephoto lens to get closeups, but as it doesn't focus any more, I bought a 2 in 1 marco / fish eye lens for my mobile phone camera. This is what I used to take these pictures.  They are made by Aukey
                      • PaulTRose
                        • Jun 2013
                        • 6463
                        • Tattooine
                        good grief, thats tiny!!  O.o
                        Per Ardua
                        • Gwyn
                          • Dec 2015
                          • 399
                          You must have very steady hands.
                            The funnels are finished, here is one, the other is similar.
                            The funnel caps photos were taken with a phone camera macro lens, which explains the curved edges of the photo etch hold and bend tool
                            The funnel is only placed.  The first pair of oerlikons installed.
                              Been a long time since my last post, hopeful, I'll be post more regularly now.  Here are some of the forward superstructure and main guns ready for painting.
