1\200 IJN Shokaku (card kit)
  • peterairfix
    • Jul 2012
    • 11080
    #16
    Carrying on from my last Post the first section of keel and bulkheads is finished and the lower and upper parts have strengthener to separate the and it also acts as a former when the outer layer is attached.
    • dave
      • Nov 2012
      • 1829
      • Brussels
      #17
      Coming along nicely Peter.
      • flyjoe180
        • Jan 2012
        • 12433
        • Joe
        • Earth
        #18
        That is comings long rather nicely Peter. I don't envy your task with all those 1/200 scale A6M's, but the one you displayed above looks great.
        • peterairfix
          • Jul 2012
          • 11080
          #19
          I have now just finished the middle section and now joined it to the front and add the middle corners and added some scrap joining pieces
          • spanner570
            • 15435
            #20
            Good work Peter - and fast too!
            It took me a week to build my bulkheads and frame work, and the ferry I made was less than a foot long, so top marks on such rapid progress.
            • peterairfix
              • Jul 2012
              • 11080
              #21
              Apologies for the quick work as the glue I have dries super quick.
              I have now finished the final rear third to achieve the full length although it's not yet attached.
                loving this build.
                That is going to be a beast!
                lovely work so far.
                  • 22771
                  #23
                  Just seen this Peter and some stunning work so far.
                  • spanner570
                    • 15435
                    #24
                    No need for any apologies Peter. I am just amazed how quickly the model is going together - and it's looking good too.
                    Top job.....
                    • peterairfix
                      • Jul 2012
                      • 11080
                      #25
                      Next up on this build is the lower hull plate's quite simple as it's just cut and wrap over with no bending.
                      And I have also have the poop deck in place.
                      • spanner570
                        • 15435
                        #26
                        Taking shape nicely Peter.
                        If you don't mind, here's a tip.....
                        See where the poop deck dips between the bulkheads? i don't know if your kit has them already, but I cured this by making some card stiffeners from scrap and fitted them tight between the bulkheads and up to the underside of the deck. This gave good bracing to the deck and also a nice clean, straight edge to the deck and ensured an equal margin around the 'upstand' when the upper hull is glued in place.
                        I put a load on the side of the model too. This stopped any chance of any 'in and out' when the hull proper is glued on.
                        I hope the above is of some use to you.
                        Ron
                        • peterairfix
                          • Jul 2012
                          • 11080
                          #27
                          See where the poop deck dips between the bulkheads? i don't know if your kit has them already, but I cured this by making some card stiffeners from scrap and fitted them tight between the bulkheads and up to the underside of the deck. This gave a nice clean, straight edge to the deck and ensured an equal margin around the 'upstand' when the upper hull is glued in place.
                          Ron
                          I had noticed that so i will take it off and try again
                            Freakin wow
                            • spanner570
                              • 15435
                              #29
                              No need to try and take it off Peter, you could well damage the piece, just add some stiffeners underneath the deck. If you re-do it as is, it will probably happen again. That's the down side of card I'm afraid. You need lots of strengthening over and above the actual construction.
                              I put extra stiffeners between the bulkheads on the hull too. This helped prevent any 'in and out' when the sides are glued on
                              • peterairfix
                                • Jul 2012
                                • 11080
                                #30
                                Time for another go on this one I have got all the sides glued on and the first of the decks being my first card kit there is a few mistakes on the bow but I will sort it at the end of the build and probably a repaint of the bottom half.
