the officer's quarter's painted , but looking at them here , a few touch up's are needed
heller le glorieux 1/150
finally got a bit of work done , the 10 upper gun deck cannons you see roughly rigged , and the gun port door's on . a bit of touch up paint work too , I just noticed
Steve, use a hair dryer to warm it a bit first, then work the mast much as you are holding it now and gently bend the mast to the correct 'straightness'
You will have to 'over bend it' first, then it will come back to the required shape when it cools.
Obviously be very careful not to over do the heat.....just warm the plastic - no more than that.
Another way is to place the mast in a small hole and straighten it with temp. rigging. Then heat it gently without any manipulation from fingers and just let it do it's stuff naturally.....
RonComment
thank's for that ron , didn't think of a hair dryer , let you know how I go . was thinking of just using the rigging , but that would put too much pressure , on too thin a plastic .Comment
Only too glad to be of some help....
Looking very nice too.
You probably won't get the mast spot on true, but, as you point out any bend left will be removed during the rigging proper.
i know it's far from finished, but how about a very thin slurry of green oils on it's bum?Comment
