That's all the sanding done and I have finished off the temporary second layer of planking witch contains the portholes its in place and once I have done the other side it will be permitley[ATTACH]283637[/ATTACH] [ATTACH]283638[/ATTACH] [ATTACH]283639[/ATTACH] [ATTACH]283640[/ATTACH] [ATTACH]283641[/ATTACH] fixed and portholes drilled.
Pete's 1/250 Build the Titanic
This will be it for a few months while I do me group builds.
Here's where I am at all the second planking has been done and portholes drilled out.
Including the unique five portholes on the bow [ATTACH]283850[/ATTACH] [ATTACH]283851[/ATTACH] [ATTACH]283852[/ATTACH] [ATTACH]283853[/ATTACH] [ATTACH]283854[/ATTACH]Comment
Slight change or plans I will be using my new titanic for the remainder of this build as it's at the same stage of build but a bit of a better build quality[ATTACH]283966[/ATTACH]Attached FilesComment
Here's an update all the portholes have been drilled out and A&B deck sides have been fitted just the final sanding to go before painting[ATTACH]284068[/ATTACH] [ATTACH]284069[/ATTACH] [ATTACH]284070[/ATTACH]Comment
Here's another update all the small brass portholes that I will be using are in and the first coat of applied also the rudder has been fitted along with the propshaft wings.
And I have started on the promenade deck walls[ATTACH]284102[/ATTACH] [ATTACH]284103[/ATTACH] [ATTACH]284104[/ATTACH] [ATTACH]284105[/ATTACH] [ATTACH]284106[/ATTACH]Comment
A quick request could one of the mods put 1\250 scale into the title for me.
And here's how its going I have got the top decks on and varnished and [ATTACH]284220[/ATTACH] [ATTACH]284221[/ATTACH] [ATTACH]284222[/ATTACH] [ATTACH]284223[/ATTACH] [ATTACH]284224[/ATTACH] [ATTACH]284225[/ATTACH] nearly finished all the boat deck structures.Comment
Moving on a bit I have now go the promenade deck sides fitted and the vents are finished and in place and it will be getting a second coat of paint.[ATTACH]284297[/ATTACH] [ATTACH]284298[/ATTACH] [ATTACH]284299[/ATTACH] [ATTACH]284300[/ATTACH] [ATTACH]284301[/ATTACH] [ATTACH]284302[/ATTACH] [ATTACH]284303[/ATTACH]Comment
Another update all the painting is finished with the exception of the stripe and I have started on the many deck fittings also I have finished the funnels and painted them as well.[ATTACH]284347[/ATTACH] [ATTACH]284348[/ATTACH] [ATTACH]284349[/ATTACH] [ATTACH]284350[/ATTACH]Comment
Here's today's update I have started on the many small pieces that will be filling the decks also I have put all benches on and the docking bridge has been started and the brass etchings along the hull[ATTACH]284508[/ATTACH] [ATTACH]284509[/ATTACH] [ATTACH]284510[/ATTACH] [ATTACH]284511[/ATTACH]Comment
A progress report going from bow to stern I have been adding more details and I have the first two cranes finished plus some steam winches and the benches with some more details added to the funnels here are the pics.[ATTACH]284874[/ATTACH] [ATTACH]284875[/ATTACH] [ATTACH]284876[/ATTACH] [ATTACH]284877[/ATTACH] [ATTACH]284878[/ATTACH] [ATTACH]284879[/ATTACH] [ATTACH]284880[/ATTACH] [ATTACH]284881[/ATTACH] [ATTACH]284882[/ATTACH] [ATTACH]284883[/ATTACH]Attached Files- P1030750.JPG (2.7 KB, 0 views)
