Revell 1/700 USS Independence
    This model has been waiting for some work for I don't know how long. I've recently re-started on her and added a little more detail from the GMM etched set. The boot topping has been painted and I'll mask it when the hull is painted. Hope to get regular updates out.
    I wouldn't normally apply a white primer to a ship model but the camouflage scheme has a few white areas which were designed to reduce the depth of shadow in some areas.
    Photos to follow.
      The white will also help to get a slightly faded effect to the main hull colours. The white areas are now masked and ready for airbrushing. I'm going to paint the flight deck first and when that has fully cured I'll mask that and begin on the hull.
      • flyjoe180
        • Jan 2012
        • 12407
        • Joe
        • Earth
        That's looking good David. Looks ghostly in white
          Thanks, Joe. It does look rather different doesn't it.
            Finished most of the main painting and now it's on to the detail painting. I also need to replace the mast structure which unfortunately got damaged. Fortunately there is a second mast in the GMM set which also provided the railings etc.
            Thanks for looking.
              Currently I am assembling Eduard 2omm Oerlikons!
              Only another 20 to do
              • spanner570
                • 15414
                Nice paint job, David.
                Plenty of Battle Honours during WW2, only to end up on Bikini Atoll for the 'A' Bomb tests!
                ....good luck with the remaining 20 Oerlikons.
                Ron
                  Doing 1/350 oerlikons is bad enough, but these are 1/2 the size of those. Good luck and I hope the carpet monster doesn't gobble too many of them
                    Thanks, Graham. Should be fitting them some time next week. Not lost any so far......famous last words
                      All done and ready for fitting!
                      • spanner570
                        • 15414
                        Nicely done, Dave. I bet you're glad to see them completed...
                        Ron
                          Ron
                          Good to get them finished
                            I've made a start on the seascape today.
                            The swell is created from some heavy watercolour paper supported on a cocktail stick. The edges are feathered into the base with some filler.
                            Next, I applied a base coat of Vellejo Prussian Blue.
                            When this has dried out I'll apply another coat of blue (this shade is a little too bright) then begin the texturing with an acrylic gel.
                            • spanner570
                              • 15414
                              Nice to see a different approach to mine when creating a seascape - More the merrier!
                              Interesting stuff....
