1/142 Revell North Sea Fishing Trawler .. A voyage to the fishing grounds of the Arctic. Building the vessel.
  • spanner570
    • 15401
    I've been quietly pootling along building this nice looking kit for a few weeks now.
    Initially I was going to make it in to a rusty old wreck, but it's too nice a kit to trash - not just yet anyway!
    I'm going to try and model her leaving port, head butting the North Sea and then in the Arctic fishing grounds.
    Unfortunately I made a start before I remembered to take the sprue pictures......:upside:
    So here's the box art and remaining sprues.
    [ATTACH]309130[/ATTACH]
    Two little crew members are included.( below the coil of rigging)
    [ATTACH]309131[/ATTACH]
    Two piece hull glued together and foredeck added. I was going to hack off the lower hull but I'll need some of it left on for future use......:thinking:
    [ATTACH]309132[/ATTACH]
    Nice moulded deck detail but the deck planking is way too wide and will have to be scraped off using an old wood chisel. - Sorry G.C. Race!
    [ATTACH]309135[/ATTACH]
    Cheers.
    Ron
    • 15693
    Hi Ron
    These old Revell boats, all odd scales, make up rather well. It will look great heading out from Hull or Grimsby. You're good at these sea scapes. As a child I went to school in Hull and regularly watched the trawlers heading out. I thought for a moment it was planned to go on the Normandy village dio instead of ducks! :tongue-out3:
    • Steve O
      • Dec 2017
      • 327
      Very nice kit Ron i have always had a soft spot for fishing boats, and yes i think it's to nice to trash.
      All the best Steve.
        I love those kits Ron!!
        I must build one someday :smiling6:
        • PaulTRose
          • Jun 2013
          • 6460
          • Tattooine
          be nice to see how this builds up
          Per Ardua
          • skinflint
            • Apr 2007
            • 271
            Will be good to follow this build, I'm considering this as a future build.
              • 22770
              Well I'm in watching Ron,
              • JR
                • May 2015
                • 18273
                Ron !
                Not as bad as some miss use of chisels I've seen. I have been known to do the same .
                Looking fwd to the water seascape.
                John .
                • Steve O
                  • Dec 2017
                  • 327
                  Ron don't forget my box of frozen cod, lol, looking forward to the progess of this one.
                  Steve.
                  • spanner570
                    • 15401
                    Thanks boys, nice to have you all along for the voyage.....Cast off, me 'arties!
                    I'll be using brushed on Vallejo Model Air acrylics. Just as well, 'cos if it was Model Colour, I would have had to thin the paints using up some valuable tap water!
                    First coat applied to hull, deck and the start of the superstructure. Foredeck left in white plastic for now.
                    Yes I know - "Jeez Ron, that looks rough!" No hurry though. 'Patience is a virgin.' Such is the brush painter's lot. But consider this, I'm introducing weathering streaks with each subsequent coat, no need to worry if a bit of paint goes where it shouldn't, so no need for any masking tape. I can cut in neater later if required. This is going to be a hard working trawler, so neat paintwork goes out of the window! (within reason)
                    [ATTACH]309318[/ATTACH]
                    Wide deck planks scraped off. I've left a few on here and there. I don't like dark coloured wooden decks. I prefer a bleached, hit and miss look.
                    [ATTACH]309319[/ATTACH]
                    Cheers.
                    Ron
                    • Steve Jones
                      • 6615
                      A bit late to the party Ron. Nice to see such variety on your blogs. Great stuff.
                      • spanner570
                        • 15401
                        Thanks Steve.
                        Here's the superstructure. Again, most of the detail is moulded in.
                        This section contains only 5 pieces.
                        Neat painting, what!
                        [ATTACH]309809[/ATTACH]
                        ...hatches painted and a bit of squiggle painting to darken the interior prior to fitting the superstructure.
                        I've given the main deck a couple of coats of different shades to vary the bleached planking. Keep in mind this is a hard working trawler.....
                        [ATTACH]309818[/ATTACH]
                        A word of advise here to anyone about to, or thinking about building this model. You can just see some white plastic card fixed to the sides of the superstructure. This was necessary in order to fill the huge gap between it and the upper deck. So unless I dropped a bo***ck somewhere you might have the same problem. Just beware...:thumb2:
                        [ATTACH]309821[/ATTACH]
                        Hull painted and ready for weathering. I don't use masking tape, preferring to run a suitable piece of wood around the hull marking with a pencil as I go merrily along, then paint freehand.
                        [ATTACH]309822[/ATTACH]
                        Cheers.
                        Ron
                          • 22770
                          Nice work so far Ron
                          • JR
                            • May 2015
                            • 18273
                            Afternoon Ron .
                            Nice result on that timber.
                            • spanner570
                              • 15401
                              Cheers chaps.
                              Cutting out all the small bridge windows is beyond my skills, so I've decided to paint the 'glass'
                              Still a bit of tidying up to do around the window frames, but I'm happy enough with it.
                              Superstructure fitted.
                              [ATTACH]309883[/ATTACH]
                              [ATTACH]309884[/ATTACH]
                              One piece deck winch fixed and partly weathered.
                              [ATTACH]309885[/ATTACH]
                              Thank for looking.
                              Ron
