  • JR
    • May 2015
    • 18273
    #1621
    Nice explanation explanation Tim, always wondered what they were and for .
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #1622
      Hi Chris. As I promised, here are some shots of my 5 sided broaches....
      [ATTACH=CONFIG]n1139181[/ATTACH]
      These are the ones I have, from really small (0.4 ish) to larger. As you can see, they are nothing like files. You can hold them in a pin Chuck, or between your fingers.
      [ATTACH=CONFIG]n1139182[/ATTACH]
      Here is a (hopefully) clearer shot of the biggest one. It shows that they are tapered with five equal flat sides. There are no teeth, the edges do the cutting. This enables you to gently increase the size of a hole, and the odd number of sides means it won’t drift off centre. Broaches are particularly useful if you want to make a hole big enough to take a wire of unknown size. You just drill smaller than the wire and broach the hole out to the size you want. For sheet work it can save you a lot on drills because these are more robust and you don’t need to keep every single size in stock. These are obviously no good for blind or deep holes though.
      I find them an invaluable tool to have when dealing with etch, especially when building something with a lot of holes that need opening up. Well designed etch should always have undersized holes, because you can always open the holes to size, but if the sheet is over etched you can’t put anything back.....
      Hope this helps
      YEA Tim i see now what you mean all it does is boar the holes out bigger but my stanchion holes are about half a mm do they come that small at the tip ? cheers for the info an like John i never seen them before but to me they seem like a bradall
      chris
        • 18932
        Hi Chris. I suppose they are a little like a bradawl. They work the same way, but are more refined being five (not four) sided and with a less pronounced taper. This makes them much more controllable in use. They are a watchmakers tool I believe.
        in answer to your question, yes, they do go down to 0.5. The smallest one I have ((the black handled one) will open up 0.3 mm holes.
        For larger holes you can use a round needle file, but the secret is to rotate it anti-clockwise. If you rotate it clockwise it will grab and bind, Being round it may drift the hole though, so is best used where absolute accuracy is not required.
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #1624
          MANY THANKS Tim for the info an pics but i think before i buy these broaches im goin to try useing my small hand drill on just one an see if they will drill out ok an as its hand powered there will be no surge of power to the hole in the stanchion to cause a wring to the stanchion cheers for your help
          chris
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #1625
            HI ALL update time
            an im puttin on the same pic of the ship so you can all see where an what ive built an what it did on the real ship an what ive built are all in the purple butfirst the ship Click image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #1626
              NOW for the last month or so ive been building the medium range gunnery systems 3 plessy type 903 fire controll systems an i must admit they have been boreing to build as there are so many awkward angles on them its been a nightmare to build them all its been is measure an cut an the same again about 50 times over an they are still not finished as they will have to be sprayed matt light grey then i can fit the main dish on the units fronts but its been a drag never thought id get them to this stage but had to as they are on the ship so got to be built an here still building themClick image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #1627
                an here all done for now an the ones at the front are the guns fire controll systems Click image for larger version
                • Steven000
                  • Aug 2018
                  • 2830
                  • Steven
                  • Belgium
                  #1628
                  Well they look very complicated indeed, but it's very nice work, will add a lot of detail to the decks :thumb2:
                  Steven
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #1629
                    different angle s shots Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #1630
                      Steven
                      OH Cheers Steven thats cheered me up a bit if you like them an yes now they are almost built hopefully they will set the deck s off with their complex struckures but these were so hard to build even with jens help an i nearly said s*d it for a while but i thought well they will still be there waiting to be built so it was a case of get stuck in an jen gave me encourgement to build them an hope you are well
                      chris
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #1631
                        an the ones at the back are the purple ones again an they are the same type of fire controll systems an they are fitted onto the rear deck nr the rear funnel on each side of the ship but they have a different pick up head on them an they controll the seacat A/A missle system if im right on that Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #1632
                          top view of the pesky little blighters lolClick image for larger version
                          • BattleshipBob
                            • 6805
                            • Bob
                            • Cardiff
                            #1633
                            Very nice Chris
                            Usual high standards sir!!
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #1634
                              an here some of the other bits i been building as they cant be fitted yet but i thought id build them an get them out of the way an pack them away till they are needed oh i want to do something with eletrics aaarrrggghhh but thank good ness im now starting on the eletric coolin fans oh heaven lolClick image for larger version
                                • 18932
                                That’s a really nice job. Those structures are built up of complex angles. It is just like the designer was given the brief to make them as hard for a modeller to replicate as possible.....
                                Going to look epic on the water.....
