  • Lee Drennen
    • 7711
    #1756
    Chris. Nice updates you been at this for a long time keep chipping away at it
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #1757
      Originally posted by Mini Me
      Looks fine to me Chris......I do see from the plan sheet beside the funnel that the tubes are larger in diameter, considering what you had to work with, it came out very well. Rick H.
      OH Cheers for that Rick an the other guys sayin that has made me feel a little better as i like to try an get things right as near as possible but sometimes we have to take what we got hav'nt we anyway as i said in the other post they may not be seen much as a lot is still to go on the deck in front of them an thanks for your comment
      ATB Chris
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #1758
        AN HI ALSO TO YOU TO Lee yea its been a long build so far an not even half way yet so for now im leaveing the rear funnell even though its still got to have all the ladders on it but they will go on after it been sprayed grey so next up is the really hard front funnel as this one will be steamin an will need to have the flexi tube fitted to it an then down to the smoke or steam unit an this is goin to be hard a i cant see in the S/S TO line it all up so thinking cap on for the next wk or so tryin out different ideas
        ATB an hope you feel better Lee
        chris
        • Peter Gillson
          • 2594
          #1759
          Great progress - as always.
          Peter
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #1760
            Peter
            THANKS Peter im always striveing to the finish line which is not even a light at the end of the tunnel yet so onwards an up
              Just had read through , my you've been busy Chris.
              I've tried bending plastic pipe using various methods, from hot ( near boiling ) water, hot sand as seen on UTube and sad to say that styrene tube refuses to play.
              That's why I ended up using copper bends and those drinking straws as you have done .
              That funnel is build on its own, you should be really pleased .
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #1762
                HI John :thinking: well i should think youve nr wore up your like button on your pc on this lol :rolling::smiling: an many thanks for all the likes thats keepin my mojo up like the other guys have said THANK YOU ALL an yes its a job to do the bends as they are so tight a bend an i treid several different ways to do the bends but the pipe always split or cracked so it was down to the benable drink straws as i said before i would love to have used brass tube but i dont have the tools to do it so its use what i have got an yes i think you an the guys are right it dont look to bad an im warmin to the idea of how ive built it an hopefully when it all sprayed grey i wont notice it
                ATB
                Chris
                • ozdell
                  • Apr 2020
                  • 365
                  #1763
                  Hi Chris wow that funnel is pure awesome , is the fan blades behind the mesh panel, is there a second funnel to build keeping you busy, I have a couple of those doors on the bridge and crew accommodation block, will have a closer look at one of your other doors so I can copy, mine wont be open.
                  How are you going , take care Tony
                  • adt70hk
                    • Sep 2019
                    • 10444
                    #1764
                    Chris
                    Apologies got very behind on this.
                    Words genuinely fail me when I look at what you're doing.
                    It's looks spectacular now. Can only imagine what it will look like once finished.
                    ATB.
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #1765
                      AN HI Tony glad you like the funnel an yes the fan blades are all fitted in behind the mesh an yes there is a second funnel as the one you have been lookin at is the big rear funnel as in real life i shoud think it stood 40 to 50 ft high as the navy added quite a few feet when they converted tiger from a all gun criuser to the very high hangar to fit in 4 seaking choppers an yes you ok to copy my W/T doors for your bridge no problem an can we see some more pics of what you are doin on your ro/ro ferry an did you manage to build the bulbus bow on the ships front ok ?
                      chris
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #1766
                        Originally posted by adt70hk
                        Chris
                        ATB.
                        AN HI Andrew an no need to apolagise as you cant keep up on every thread on here as this is such an active forum as thats what i like about it all you guys talk daily an thats how it should be as other forums im on well im lucky if i get a answer once a month so this the best forum to be on i think anyway an very glad you like the build of tiger as im fairly pleased at how at how the build is goin an yes i think you are right it should look a nice model when finished an sailing an many thanks for your kind comments
                        cheers for lookin in
                        chris
                          • 22788
                          #1767
                          Well Chris, I've had a good few minuets catching up on this fantastic build. the work that you have put into this so far, is just outstanding.
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #1768
                            HI Ian well im really glad you are likeing the build an yea it has been a lot of work an still a heck of a lot to come but for me each bit that im building is like a seperate model so that when ive built one bit i think ok whats next up so its another seperate model build again so in realality its loads of seprate models which will all be assembeled together to make the one big ship model at the end so when i think about this ive built about 20 seperate models through the two yrs build time so far an im enjoyin it most times as fair enough some bits have been boering to build but that had to be as they are on the ship thanks for looking in
                            ATB chris
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #1769
                              UPDATE TIME GUYS
ID:	1141660 i built it before i thought about havin a steam unit fitted in an this pic show that i just fitted streaked plasticard to represent the cooling vents as these are on the real ship here an they are at the lower right side corner
                              • BattleshipBob
                                • 6821
                                • Bob
                                • Cardiff
                                #1770
                                Usual very high standards Chris.superb :thumb2::thumb2::thumb2::thumb2::thumb2:
